Americas What is your petrol US gal mpg?
That‘s pretty good. Plus you’re at what 5000-6000ft above sea level?
6,000+
The only reason I like knowing accurate fuel consumption is for range. In some parts of the Southwestern US it can be important.
I know it's an IG forum, but this little 90 was brilliant off pavement.
actual calculated mpg/ onboard computer
1) 13.8/ 16.6
2) 14.1/ 16.1
3) 13.4/ 15.7
4) 14.3/ 16.7
5) 13.1/ ??
new:
6) 14.2/ 16.5
Federal law allows factory speedometers to read 10% higher or lower than the actual speed (49 CFR 393.82. Since speedometer accuracy probably tracks with odometer accuracy, why would any auto maker not have their speedometers read high? A 10% overestimation of miles driven should translate to some very real savings in warrantee claims.
Heck of a good point there!
I believe the speedo is allowed to be 10% high and 0% low.
Mine reads 78 mph when traveling a true GPS verified 75 mph.
Assuming the odometer has the same error, when it reaches 30,000 miles; I will have actually travelled 28,846 miles.
It also would also skew my manual calculations of mpg since I use the odometer to determine miles travelled.
14 mpg would, in reality, be 13.46 mpg.
Next fillup:
1) 13.8/ 16.6
2) 14.1/ 16.1
3) 13.4/ 15.7
4) 14.3/ 16.7
5) 13.1/ ??
6) 14.2/ 16.5
7) 13.9/ 16.2
I live in Charlotte, NC and drive on both highways and around the city and I average about 16.5-17.5mpg.
Computer average, or one you manually calculate? There seems to be a significant discrepancy (see nuclearbeef's numbers).
Speedometer almost never track with odometer accuracy.
OK, I'll bite. Porsche 911 is and is advertised in the operators manual as being 3 MPH above what is actual. Silly thing considering there isn't much difference between 147 MPH and 150 MPH. :ROFLMAO:
Rupert only has 500 miles right now so I would say not a good comparison. Right now I am averaging about 15.5 on the trip computer, so it is most likely less than that if the math calc was done. I would say it will most likely be pretty settled after 2,500 miles and will post up again at that time. Honestly, if it got 10 MPG, I would still love it. I appreciate gas guzzlers, I wish everyone drove one. Guess what business I am in?
Not with a turbo/supercharged engine.
Why would this be?
Less drag due to reduced density.
You wouldn’t see the increase in engine efficiency due to reducing pumping losses as in a NA engine. But the turbo having to work harder should have only a slight reduction (if any) on overall engine efficiency.
Why would this be?
Only to reduced drag.
Non-forced induction engines tend to lose power simply because of less air density, and since/if they are running more or less stoichiometric air/fuel ratio, they use less of fuel.
Forced induction more or less masks that effect.
N/A engines will lose power at any given throttle setting and will make less max power.
But the air/fuel mixture will remain the same.
You will just need to use a more open throttle to make the same power.
Going over the Coal Bank Pass on U.S.550 in the Range Rover Classic was a flat-out affair. I thought I'd burn a lot of fuel - but the gas mileage ended up a little better than at sea level.
My first tank hand calc was 16.5. Just ran a tank through primarily highway with punishing headwinds and was down to 11.6 which almost makes it a no go for long distance remote use since you have no idea what conditions you will face. I hope it is an anomoly.
Adding-US Gasoline version and under 1000 miles on odometer.
