Diff oil level measuring tool?
Pete Brown
10:30 AM
Anchorage, Alaska
Apparently there is a tool shaped somewhat like an Allen wrench which functions like a dipstick to measure differential oil levels when replacing diff oil. Should be very simple to duplicate. Can the tool be purchased from Ineos? Alternatively, Is there a photograph of the tool floating around showing shape and dimensions so I can fabricate one?
Why do you want to buy such a tool? Make one.! All you need is a wire hook with a leg length of approx. 35 mm on the short side. If you then fill the differential with exactly 2.1 liters of oil, the oil level will be approx. 23 mm below the filler opening. You can always check the oil level using a corresponding mark on the hook mentioned above. However, unless you do have an oil loss in the differential area, there will hardly be any reason to check the oil level. Given the price of the differential oil (approx. 5 euros per liter), it should be much easier to simply change the oil every 25-30,000 km.
This is not !!! the INEOS tool, but it should be similar. But make sure you do not drop the tool into the differential !
Id say this is a minimum not a maximum. I'd fill until it drips from fill hole like every other diff out there. Otherwise if I can squeeze my pinky in the hole and get a drip of 90w on it then it's also good.
Keep in mind this oil is splashing everywhere even at 5mph. So slight variations in oil level will not make a hill of beans difference up or down. Just changing caster from min to max will change how the tool reads.
Fill it till it drips and run with it.
Make the tool from flat bar, bent like an Allen wrench, but drill holes the part that will contact the oil. The holes will retain oil indicating depth of fill, then you can figure out some calibration.
What happens if the diffs are filled to plug level? There has been no deffinitave answer.
Filling to plug level will be what happens in country and remote workshops with most customers being totally unaware of the technical procedures to pass on to the techs.
This would be one of the few bush ready 4wds that has made formerly very simple service tasks excessively specialised.
100% nothing. The tool is just giving you a minimum level. The difference between minimum and filled to plug level is negligible.
It's probably some Euro regulation to prevent spillage/wastage/contaminant disposal.
When i did my diff fluid change, i assumed i could just fill until it dripped from the fill hole. But that is not the case!! I carefully measured the fluid and it was nowhere near the fill hole. I even added an extra 100-200ml and it was still no where near the fill hole. I didn’t want to add more for the fear of breaking something due to overfilling.
I overfilled a diff once and it wasn't pretty. 90wt backed up out of the vent line and dribbled all over the place. At first I thought I'd blown an axle seal. What a mess....on the wife's car!
Overthinking it! Open that draw/box half full of random Allen keys.
Take out a black one (shiny won't show the oil level) and dip it in the filler hole.
Can anyone that has changed their front and rear diffs confirm there is no gasket/washer/oring? My dealer told me there was not but I have a hard time believing this and want to make sure I have everything I need before draining. Thanks
I don’t recall a washer, funny enough i think i asked the same question to the dealer. I reused the drain/fill bolts.
