Front drive shaft broken
1:14 AM
Alabama, USA
just noticed, Eibach USA has added the following statement to their 2.5 lift spring description.
Tested with factory dampers. Recommended to pair with Eibach Pro-Truck Reservoir Shocks. Damage could occur to factory drive shaft with change in ride height. Consult instruction manual for proper installation.
C-Mack
12:14 AM
Logan, Utah, USA
A real vote of confidence when a manufacturer states out in the open their own plausible deniability. Do we need anymore evidence that big lifts on a Grenadier should be avoided at this stage until more engineering is done to the vehicle?
1:14 AM
Alabama, USA
I just double checked. The statement is in the description for ALL of their Grenadier lift springs.
1:14 AM
Alabama, USA
Standard boiler plate for any aftermarket suspension. Nothing surprising about the disclaimer.
wasn't there until this week, otherwise I would have purchased the shocks when I got the springs in April or either not purchased them.
2:14 AM
Colorado Front Range
No shocks, either OEM, Eibach or from another aftermarket manufacturer will do anything to change the issue regarding the drive shaft. And if those shocks are longer than the OEM spec then they will only exacerbate the issue.
The bottom line is that suspension modifications on any vehicle, Ineos, Jeep, Toyota or otherwise involve compromises to reliability and durability regardless of whether this happens to be called out in a fine print disclaimer.
LeeroyJ
10:14 AM
Arizona, USA
The thing is in other vehicles (like Jeeps) a 2.5" lift is a tiny lift.
1:14 AM
Alabama, USA
here ya go
From what we have seen, there is an inherent design issue on the Ineos, as there have been driveshaft failures with the stock suspension. We have added notes to our instructions that specify not to loosen the track bar or control arms, and to not pull down on the axle when trying to remove the OE springs or to install the new Eibach Pro Lift springs. Failure to follow the instructions can possibly pinch or bind the boot causing a failure. In the instructions we specify to use a spring compressor to remove the springs, as well as use the spring compressor to install the lift springs. This is the method we use here and we have yet to see a failure on any of the vehicles we have tested here.
11:14 PM
Pasadena, CA, USA
I'm running a Mickey Thompson 255/85/r17 (34 x 10) on stock steel wheels and stock suspension without rub. I ran the IG from Lake city to American Basin last weekend without issue on this setup.
I’m looking at installing these today. Any issues with the gearing?
300chris
2:14 AM
Colorado, USA
255/85/17 are a fantastic combo with this truck. Running the Eibach 2.5”/1.7”
About 3000 miles on this set-up so far. Obviously will keep an eye on the CV joints, but no isisues this far (OWL did the install and disconnected the driveline prior to install). Most miles are lower speed (mostly off-road), so heat is not an issue. Have stuffed the suspension multiple times, and there is never any contact with the wheel wells.
Migs
12:14 AM
Colorado, USA
Just as FYI:
I'm putting on the TeraFlex Rzeppa High Angle CV joints today/tomorrow morning. I'm replacing the two "middle" CV joints (one on each driveshaft where they meet the transfer case), as those had the most extreme angles. I'll be doing some highway driving and offroading this weekend (traveling about 70 miles each way on highway (70-80 mph)) with these new CV joints, so can reply if there are any issues.
Side note: I talked with John Brindell (from Agile Offroad) today, who was super nice and helpful. He's had the same Rzeppa High Angle CV on his Grenadier for over a thousand miles, of both highway driving and pretty rough (not extreme) offroading where he said he really stretched out the suspension. He said his are holding up great, he has had no issues.
C-Mack
12:14 AM
Logan, Utah, USA
Just as FYI:
Let us know if there is any driveshaft droning or vibrations after you switch them out especially at highway speeds. I would assume each driveshaft is balanced as a complete assembly with both stock joints in place and I’m curious if switching out a joint is enough to take it out of balance… hopefully not. (Just a thought but maybe put witness marks on your old joints and shafts before you take them apart in case you have to put them back in and maintain their relationship to each other for balance purposes)
Migs
12:14 AM
Colorado, USA
Drove it on highway (75mph) with new cvs. It actually got rid of a slight harmonic/vibration i had between 65 & 70 mph that started after the bigger eibach springs were put on. So in an initial test drive, its smooth as butta'
Will follow up if anything changes after saturdays trail runs.
PNW_IG
11:14 PM
Washington, USA
I just passed 5000 miles since my Eibach Pro 2.5" Lift. with approximately 75 miles of light trails. (Just over 14,000 total miles) So far I have no issues with the CVs. - Probably because I carry two spares and the tools necessary to fix if needed.
3500ish mile trip I just finished.
11:14 PM
Pasadena, CA, USA
I just past 5000 miles since my Eibach Pro 2.5" Lift. with approximately 75 miles of light trails. (Just over 14,000 total miles) So far I have no issues with the CVs. - Probably because I carry two spares and the tools necessary to fix if needed.
I sure hope that continues to work well but it looks like it's just a matter of time before it lets go.
