Winter temperature records have just been set in Western Australia. 39-40 Celsius in several towns!Yes, I can understand that. I think you also have completely different environmental conditions. These information may be helpful for you.
Towing around here in central Europe at max 100km/h is not the issue. This is what I can say from own experience: Do this also regularly with different vehicles and heavy trailer. From my own experience with the Grenadier, xfer case temps are absolutely no problem in these use cases.No, you don't have to. I've been driving off-road vehicles exclusively for more than 25 years. And I work with them too. By that I mean trailer operation. Both on muddy meadows and on motorways. And the trailer doesn't just carry compost waste, but also machines and sometimes 1600 kg of live stock.
Apart from the correct tyre pressure and looking at the engine oil temperature, I've never needed anything else and I don't use this overabundance of information on the Grenadier. None of my previous vehicles have been damaged or displayed error messages as a result. I expect the same from the Grenadier.
And by the way, I would never think of driving 160 hours/km with the Grenadier.
Sounds as good of a read as and a summer favorite of Caterpillar's, "Diagnosing Overheating on Earthmoving Equipment Systems"Good question @TD5-90
Not without testing and number crunching. Too many variables. I offered this as a contributing factor but it's not the primary problem. The cooling system has a heat dissipation rating and will be effective provided the vehicle is operated within limits. Maintaining normal temperatures while blasting down the autobahn probably wasn't a top test and evaluation criteria.
This article from the electronics industry talks about how fans, ventilation openings and enclosure designs affect mass airflow rates which are necessary for good heat dissipation. Check it out if you're having trouble falling asleep.
Remember when Clarkson struggled with airflow?
Same here. Except that we call it summer.Winter temperature records have just been set in Western Australia. 39-40 Celsius in several towns!
I have also noticed. This does not appear to have occurred in any INEOS testing cycle. As you write, no problems permanently up to 135/140 km/h Unfortunately, minutes-long journeys at higher speeds are not possible. It's just something you have to come to terms with now. The car would have benefited from another 1-2 years of development and testing. Or you would have had to wait longer before buying one. At the current price, I probably wouldn't have ordered the car knowing the quality.This morning I drove about 15 - 20 minutes at max. speed (160 km/h or 100 mph). Outside temperature at that time has been around 22 degrees Celsius.
I then got a warning "motor oil level low" (yellow warning)
I reduced speed significantly and had a look at the "offroad temperature" screen. This showed a transfer case temperature of 115 degrees Celsius which was outlined in yellow.
Motor temperature and gear box where at 95 and 78 degrees by than.
The temperature of the transfer case dropped fast at the speed of 120 km/h and the yellow outline vanished after a minute. After 10 or 15 minutes the warning "motor oil level low" vanished as well and the yellow triangle disapeared.
Has someone else had this Problem before?
To me it looks like the transfer case cooling system fails at a certain speed.
I do not want to start a discussion whether or not someone should drive at this speed over a longer period, as the speed is allowed in Germany and the motor turns only 3000 rpm at that speed. Of course it is in many ways more intelligent to drive slower.
That's exactly what the wife says, along with " you're going to have an accident taking your eyes off the road and playing about with the different displays"For most of my life I have been blissfully unaware of tyre temperature, transmission temperature, diff temperature etcetera with just a vague gauge giving engine coolant temperature.
Now I have many more things to worry about.
Could the boys come and visit us?160km/hr in Australia would see two issues arise:
1. Crap roads and likely end up in the trees!
2. Police run you down, impound and crush car later on!
Usually in Germany I drive between 140 and 150 km/h on the motorway. I once pushed it to 165 km/h (gps speed) only as a test.Could the boys come and visit us?![]()
I don't find this to be the go-fast car. I'll drive it at 90mph but not much above, is just not the right car for higher speeds
It is nice to drive that fast, but:
- gasoline consumption is insanely high
- it requires a lot of concentration as it is indeed insanely fast
You'll easily pass me at that speed. Why don't you use your toot horn? Then I'll know it was you.Usually in Germany I drive between 140 and 150 km/h on the motorway. I once pushed it to 165 km/h (gps speed) only as a test.
Of course it is not a car for higher speed. But who wants to judge what a higher speed is? The Grenadier handles fine at 160 km/h. At least my one. Nevertheless it has ridiculous drinking manners at that speed. My normal cruising speed is between 110 and 140 km/h on the Autobahn.I don't find this to be the go-fast car. I'll drive it at 90mph but not much above, is just not the right car for higher speeds
Absolutely! And that's what I do most of the time.I don't find this to be the go-fast car. I'll drive it at 90mph but not much above, is just not the right car for higher speeds
It's all about what you are used to. I don't feel stressed at 160, maybe I only drive fast when the conditions allow it. But there are many days when I enjoy cruising...Usually in Germany I drive between 140 and 150 km/h on the motorway. I once pushed it to 165 km/h (gps speed) only as a test.
Just over 14kHow many Kms? It might be the Tbox isn't yet run in?
I can see the problemUsually in Germany I drive between 140 and 150 km/h on the motorway. I once pushed it to 165 km/h (gps speed) only as a test.
Calibration standard for calculating the Grenadier aerodynamic drag coefficient?I can see the problemView attachment 7868648
