Have we confirmed that the teraflex CV’s will fit on to the IG shaft? And the axle flanges?
I'm a few martinis in so my thinking might not be spot on, I don't think by adding larger tyres you effect the drive line as simply raising the whole car as opposed to lift where moving parts away from the axles.So question - presuming one DOESN’T do any lift, what size tires will fit without rubbing? And have we seen drive shaft failures when ONLY larger diameter tires were fitted, without a lift (other than the couple of stock failures)?
this is exactly my thinking as well. the geometry between the axle and the body stays the same.I'm a few martinis in so my thinking might not be spot on, I don't think by adding larger tyres you effect the drive line as simply raising the whole car as opposed to lift where moving parts away from the axles.
So when I am in Austin, it was 1 day to get it, only in Durango does it take multiple days, I am sure in Moab you could get one in Day via Amazon.I agree with you Tazzieman and I respect those that take a conservative approach to their IG. Personally, I've enjoyed modifying my IG but I accept the risk without whining. Plus, I live 20 minutes from a dealer and Amazon can deliver a Teraflex CV to me in two days.
@parb and @ECrider - exactly. The WHOLE geometry, I believe, stays intact - just up a bit. So no additional angle on the drive shaft. You can still pick up an inch of clearance that way without the drive shaft risk. If the extra clearance is really that important, probably the best solution. I think the martinis made you lucid and succinct, @ECriderthis is exactly my thinking as well. the geometry between the axle and the body stays the same.
So a 275/70/17 or what?i have 33.5" tires on mine. i know several others who have that size tires on (1.5" larger than stock) without a problem, several who are much more hardcore offroader than i am.
yes, the one for the Jeep JL Teraflex 1745000. I've got one coming in and have talked to another owner that has one installed and has ~500 miles on it with no issues.Have we confirmed that the teraflex CV’s will fit on to the IG shaft? And the axle flanges?
My recollection of the Ineos promotional videos and trips and photos before release is that they included many instances where the factory itself was using 35" tires, for example that big Africa trip they did. My understanding is that 35" tires will not fit without a lift. So I assume during those factory tests that Ineos had taller springs installed? Does anyone have any insight on that?That’s fair enough if you’re prepared to take the financial risk. But I just don’t get it myself.
Are we looking at that as just an easily obtainable road-side repair part? From the looks, it seems that the Teraflex would be subject to the same failures as the stock unit? Or am I missing some reason why its design is better than stock?yes, the one for the Jeep JL Teraflex 1745000. I've got one coming in and have talked to another owner that has one installed and has ~500 miles on it with no issues.
There have been reported failures with the stock springs. I think there was at least one person earlier in this thread. I don't know if they had larger tires or not.So question - presuming one DOESN’T do any lift, what size tires will fit without rubbing? And have we seen drive shaft failures when ONLY larger diameter tires were fitted, without a lift (other than the couple of stock failures)?
From the TeraFlex website:Are we looking at that as just an easily obtainable road-side repair part? From the looks, it seems that the Teraflex would be subject to the same failures as the stock unit? Or am I missing some reason why its design is better than stock?
I believe this was a c clip failure, not a boot failure.There have been reported failures with the stock springs. I think there was at least one person earlier in this thread. I don't know if they had larger tires or not.
I think it was @Logsplitter - who was running stock suspension and tires? I can’t rememberThere have been reported failures with the stock springs. I think there was at least one person earlier in this thread. I don't know if they had larger tires or not.
That’s correct it was my vehicle. No mods bar some extra electrical sockets.I think it was @Logsplitter - who was running stock suspension and tires? I can’t remember
And did the issue end up being c clip? I can’t remember the detailsThat’s correct it was my vehicle. No mods bar some extra electrical sockets.
The Ineos Kavango Safari vehicle is running 34” The Ineos guys were very secretive or just plain didn’t know what has been done to suspension or running gear when I asked at the Game Fair UK.My recollection of the Ineos promotional videos and trips and photos before release is that they included many instances where the factory itself was using 35" tires, for example that big Africa trip they did. My understanding is that 35" tires will not fit without a lift. So I assume during those factory tests that Ineos had taller springs installed? Does anyone have any insight on that?
Yes the C clip that failed.And did the issue end up being c clip? I can’t remember the details
the dirt box overland vid has Kenda 35 x 10.5 on a stock suspension. he says no rubbing.So a 275/70/17 or what?
No spacers on the springsthe dirt box overland vid has Kenda 35 x 10.5 on a stock suspension. he says no rubbing.
