psi is an abbreviation for ...Jean, if you change units to "psi" everything will make far more sense!
pounds per square inch
There are only two of these words I understand: "per" and "square", please explain the other two words
I'm with my nearly 3yo granddaughter right now and she is learning all the terms from this channel.psi is an abbreviation for ...
I also had the same phenomenon with the yellow and white fonts.On Wednesday morning, the day I had to go to my dealer I got a low pressure warning. Strange, the right front tire was white colored!
I have a cheap Chinese compressor, and decided to inflate the tires myself (to test the compressor AND my battery behavior, while motor wasn't running), and did put the pressure of the front tires to 2.8 bar and the rear to 3.0 bar. I knew this was too high, as my car was unloaded, but this was a test as I said, knowing that deflating is easy. The Chinese compressor was slow, but behaved very well, nice toy, and the battery voltage went down from 12.8 Volt to 12.3 Volt, but after inflating, the CTEK Smartpass pushed the voltage of the main battery up to 12.7 Volt (I have the dual battery system):
Main battery voltage that day:
And OOH surprise, after driving some kilometers on the motorway at 125 km/h, I got again a tire pressure warning, picture taken when arriving at my workshop/dealer. Now the front left tire had a white color instead of orange!
And then I got a extensive explanation from the Hedin/Ineos guy at my dealer, but basically he said this:
Wondering if the computer of the car is detecting the load of the car.
- That I should inflate my tires when they are cold (euh, that's what I did!)
- That I should NOT inflate above 2.6 bar (euh, the sticker inside the car tells me something different if the car is heavily loaded!)
Wondering if the Hedin/Ineos guy knows what is written on the sticker with tire pressures.
Anyway, I learned something.
And, my software version is still the "old" 1939 version.
Easy, 14 pounds in a stone, and 144 square inches in a square footpsi is an abbreviation for ...
How many stones in a ton?Easy, 14 pounds in a stone, and 144 square inches in a square foot
That must depend on the stones you take?How many stones in a ton?
I find it very hard to picture someone with a square foot.Easy, 14 pounds in a stone, and 144 square inches in a square foot
It's like a dog with a henway.I find it very hard to picture someone with a square foot.
I don’t believe that 3.0 bar is to much for the unloaded Grenadier. It might be a little less comfortable than the lower pressure but it will certainly do no harm.On Wednesday morning, the day I had to go to my dealer I got a low pressure warning. Strange, the right front tire was white colored!
Something you're wanting to tell us ?I hardly can feel any difference but I hope that it will have a (small) impact on the drinking manners as well.
I feel comfortable talking free of boundaries in the forums sheltered environmentSomething you're wanting to tell us ?![]()
We're a nonjudgemental lot. You are in the safe house nowI feel comfortable talking free of boundaries in the forums sheltered environment![]()
That is why I wanted to put it higher, but I don't want the warnings.I hope that it will have a (small) impact on the drinking manners as well.
No that is not correct. TPM still works in off-road modeWhen you flip the switch to offroad mode, the TMPS no longer gives a warning. I am going off memory.
yes that is my understanding, other forum members have changed tyres and/or wheels and kept original TPMS without issue.But changing the tyres should only need a "relearning" procedure, which is different for each car.
Can anyone confirm ?
