- Local time
- 3:51 AM
- Joined
- Dec 26, 2023
- Messages
- 417
- Reaction score
- 506
- Location
- Albuquerque, NM, USA
You know it. Tom Woods saved me last summer by over nighting a Rubicon Out Put flange for me in the Sierras.
Hi Tazzieman, hope your troubles are all sorted? Question? What was the failure and did it get fixed under warranty? Was it the drive shaft or transfer box? How may km's had you done and did you have an Eibach lift kit added? I have one of the first QM's in Australia (May 2024 delivery) and my drive shaft has just failed just on 24k's and I had a 35mm Eibach lift kit done on it. Mine just went 'pop' doing a basic 4WD course on forest fire trails. I'm trying to see how many others have failed and if they were repaired under Warranty.Note to everyone : check your roadside assist small print, and insurance small print.
It's a costly exercise if you are stranded remote (easy to be "remote" even after short journeys in places like Tasmania)
And of course , it's an island here - and if you miss the big ferry because of delays, it's going to be awkward to say the least.
As I've said before , imagine the worst case scenario...and double it.
Then you can prepare the trip.
Hi Gav, Swampy here from Sydney. Hope all your troubles got sorted. Question(s). Did they find the cause of the bang and thudding? Did it get repaired under warranty? Last question? Did you have a lift kit done? My QM has also failed on 6/12/24 doing a 4WD Basic training course at Lithgow. Same thing. A bang and thudding. Its in with Dealer to be 'decided if a warranty claim".I think I had a similar/same issue yesterday (Sunday) in the hunter valley NSW, doing around 30-40km/hr on a dirt road, massive bang and turning thudding noise. My Ineos did have the transfer case recall and it was replaced at 15k service. Tow truck to Gosford dealer, waiting to see what they say.
Heh there NQ94 thanks for your feedback on the drive shaft failures on the IG's. Your feedback sounds like you have a bit more depth technical knowledge on this problem.? Can you share? My QM drive shaft and rear sway bar went 'kaput' on 6/12/24 in Lithgow State forest and I'm researching how common this fault is. "CrazyOldMan" in Jersey USA has a Youtube on double cardan solution learnt from similar issue with Jeeps. Thanks and Merry Christmas. Safe travels. SwampsWhat is common all the failures have been at the transfer case cv joint. Possibly not a direct drive shaft or cv fault but a driveline angle issue that is compounded by normal movements of the engine and transmission mounting and front axle. The other issue is the slip joint is not free enough or binding in one location causing excessive load on the retaining circlip in the CV every time the prop shaft extends.
LOL!!! Way toooo much culture for us Aussies. . . we just want ours freezing cold...Well, to be frank, the czech pilsner is the best, not a lager. I think Yeungling smells weird. It comes freshly skunked. I drink modello, pacifico, and czechvar.
Nailed the discussion points perfectlyThere are three quite serious but distinct issues being discussed here, it would be great if they could be split off into separate topics so we can track what may be an emerging global warranty or design issue for Ineos:
1) Front drive shaft failure on unmodified vehicles where it is clearly a warranty and / or design issue.
2) Front drive shaft boot and / or connection failure on lifted or modified vehicles not warranty related.
3) Some kind of Fargo style US Mid-West vs North-East beer discussion, no design issue to see here.
Glad someone asked... haven;t got a clue what SOL meansWhich of the 2,435 meanings for this acronym SOL are you referring to, please?
Heh there 255/85 - Merry Christmas . Expedition HQ in Qld Australia has done the 35mm (1 inch) Eibach Pro Lift on my Quartermaster in August 2024. I run factory 17" rims and original Ko2 tyres. Hardly a 'big lift' compared to USA standards. My Sydney INEOS dealer promotes and sells a 40mm (1.5 inch) Eibach Lift Kit and the underlying question is this: If INEOS Dealers are promoting and selling Eibach lift kits, are they not also part of the problem if there is an underlying "Drive Shaft / Cardan / CV Boot issue globally that owners aren't aware of?expeditionhq.com.au down under is both a dealer and installs lifts. I wonder what they're seeing.
Eibach 35mm Pro Lift Kit - INEOS Grenadier - Expedition HQ
IN STOCK! Please email for shipping quotes. Factory ride quality is maintained. Developed by the same engineers that were involved […]expeditionhq.com.au
Eibach 35mm Pro lift kit / King Shocks Internal Res package - INEOS Grenadier - Expedition HQ
Kit includes: 4 x Eibach +35mm springs 4 x King 2.5″ Internal Res Shock Absorbers, rebuildable Fitting available at additional […]expeditionhq.com.au
