I can't see much resolution to the problem until this "dealer installed" question is answered - at least not for current owners. You wouldn't think 35mm/<1.5" of lift (excluding installation errors like
@Tazzieman mentioned) would jeopardize the running gear on a vehicle the size of the Grenadier but it is Ineos' call.
As for future production there will likely be issues addressed like a little more positive caster on the front knuckles/swivels or other steering related changes. Conversely, I doubt there's any room to lift the rear of the transfer case. The engine - with insulation cover installed - is very tight under the hood and Ineos won't delete that because of the heat retention properties it affords.
Even if Carraro allows a little more leeway in pinion angle, most of the problems on lifted vehicles are at the front output of the transfer box. The double cardan front driveshaft solution (
@Bodhi’s Grenadier I think) seems workable at low speeds but, man, that's a lot of rotating weight to throw around at highway speeds with a full-time 4WD. Will the t-case output shaft's bearing hold? Will the front pinion bearings hold?
