Merry Christmas everyone across this magnificent world of ours. Wishing everyone a safe a festive season and safe 2025.
I need to be added to the growing list (I've counted at least 10 so far from this 'post' alone) of driveshaft and underbody failures.
My Diesel Quartermaster was one of the first in Australia, taking delivery in May 2024.
I have done 26k (16,200 miles) in it due to my business in sawmills and forestry.
I run the factory supplied 17" steel wheels and KO2 AT tyres.
I love my QM - its a beast.
I have an alloy canopy with canvas built onto the tub to keep the weight low and have a 40L (10.5 gallon) water tank at the headboard which is usually half full most of the time.
Drifta did my drawers and fridge slide. I am well under my payload of 832kg.
In August 2024 I had a 35mm Eibach Pro Lift Kit installed by an INEOS Dealer in Qld who are Expedition 4WD and Big Rig specialists and in my opinion one of the best INEOS dealers in Australia. I had this done in Qld as I was working there plus their price for the 35mm Pro Lift kit was significantly cheaper than that sold by my 'home' dealer in Sydney who promotes and sells the 40mm Eibach lift kits.
I drive on the blacktop (highway and country roads). Very little gravel road work.
On 6 Dec 2024 I attended a Basic 4WD Training Course driving on forestry fire trails which is pretty tame off road driving.
As fate has it, the last wheel rut of the day in HIGH Range at about 5km/h (3miles/hr) I eased into the wheel rut and felt and heard a bang and then some shuddering. Wasn't a pleasant sound especially on a Grenadier. . . was trucked off to my Sydney dealer this week.
Diagnosis is a rear sway bar and front drive shaft failure and my dealer is 'prepping me' that because I've had it lifted it 'may' not be covered under warranty.
I refuse to accept this is not a Warranty Issue given the incident rate is growing and appears to increase around the 20,000km (12,500miles) range.
My thoughts are these from reading at least 10 similar stories across the globe within this post alone.
1. If INEOS is aware at August 2023 there is an underlying Driveshaft issue with Cardan and CV Boot issues why are INEOS Dealers still selling and promoting Eibach Lift Kits? Also seems different Dealers have different opinions on Warranty Claims.
2. IF this is a global issue then is this not a bigger engineering / design issue as pointed out by "Allrad-Oli's" from Deutschland post on 29/8/23 and by the YouTube video by "CrazyOldMan" on 3/6/23 from New Jersey USA on the multi cardan joint solution learned from Jeep issue being similar to INEOS.
For INEOS, it would be in there interest to have this fixed under warranty and 'learn' from my QM given the QM is longer and has a different configuration to the wagon. In Australia, INEOS is hoping to push the QM Cab Chassis as a contender against the Toyota LC79 which is the "King" of 4WD's in Australia.
Especially where a lift kit is a standard practise in Australia.
I'm now waiting on my dealer to tell me what's happening and if it will be repaired under warranty.
INEOS Australia, if you are reading these posts, I recommend using mine as a learning opportunity for your engineers given it's the first QM in Australia and first to fail. And currently I'm still a 'fanboy' of INEOS. Let's use this failure to learn and keep the 'Client Satisfaction Index" at a high 5 out of 5 by accepting this a warranty claim.
