Unfortunately I still don't have my car back, waiting on partsDid you have a chance yet to look into this?
I know you had some issue, what parts are you waiting on if you don't mind me asking?Unfortunately I still don't have my car back, waiting on parts
Find the part# and post it.Hose is splithard to understand how that could be on a brand new car. Either they damaged it during assembly or are using poor quality hoses. Grrrr. Either way not good, but the former is overall preferable when considering reliability in the bush. Hopefully this is isolated.
Will try.Find the part# and post it.
So we can add to our remote spares list!
@Telliottaus That’s what? Two or three weeks - for hoses? Or other parts. This is a concern ???Unfortunately I still don't have my car back, waiting on parts
Ask the Ineos mechanic where the split was and show you the part. They may or may not let you photograph the part. Those BMW style coolant hoses have so many extra joints and leak points compared to other manufacturers coolant hose applications. The cooling system is one area on the Grenadier that owners have to be vigilant inspecting to ensure that hoses are not rubbing, pinching or gathering debris that can cause damage. IMO this the one area that Ineos has let down a very good vehicle. It looks like the cooling package and hosing was an after thought and rushed.Hose is splithard to understand how that could be on a brand new car. Either they damaged it during assembly or are using poor quality hoses. Grrrr. Either way not good, but the former is overall preferable when considering reliability in the bush. Hopefully this is isolated.
Most seem to be of the Self Clamping Spring Hose Clips variety rather than a worm drive/threaded bolt type:Often it's just some hose that needs nipping up a touch.
I'm not sure these offer any benefits to the long term owner but are cheap and quick and easy to install on a production line.
Good quality constant tension hose clamps can be more reliable then worm drive hose clamps and t-bolt clamps for stopping leaks.Most seem to be of the Self Clamping Spring Hose Clips variety rather than a worm drive/threaded bolt type:
I have to say that when I was crawling around under the car it is concerning just how many hoses and joiners and connectors there are. It does seem unnecessarily complicatedAsk the Ineos mechanic where the split was and show you the part. They may or may not let you photograph the part. Those BMW style coolant hoses have so many extra joints and leak points compared to other manufacturers coolant hose applications. The cooling system is one area on the Grenadier that owners have to be vigilant inspecting to ensure that hoses are not rubbing, pinching or gathering debris that can cause damage. IMO this the one area that Ineos has let down a very good vehicle. It looks like the cooling package and hosing was an after thought and rushed.
Before I get crucified for the negativity, my work involves inspecting hydraulic and diesel power systems regularly and completing and assessing reports with both thermal images and photography from the field to assist with maintenance, failure and diagnostic analysis.
Agreed!!Good quality constant tension hose clamps can be more reliable then worm drive hose clamps and t-bolt clamps for stopping leaks.
Try 4 weeks and counting... calling every week...@Telliottaus That’s what? Two or three weeks - for hoses? Or other parts. This is a concern ???
There are hoses at each end of the pipe connecting the transfer case to the cooler I.e. between the pipe and the transfer case and cooler and pipe. The hoses are crimped on to the pipes and are one part. I need both as I had to take the cooler out and cut out the part with the hole and join the hoses together to get back home...I know you had some issue, what parts are you waiting on if you don't mind me asking?
Hmmmm, hey Ineos, how long do you think that would take Toyota? Or even Jeep?Try 4 weeks and counting... calling every week...
One of the problems with cooling stems from the tightness of the engine compartment in just about every modern vehicle.One of the reasons for the additional cooler are the high beams in the grille.
