Hi
@Mena2, the right footwell wires are connected to INT2 of your overhead panel and that switch is powered only when your truck is switched on (ignition at ACC). So you should wire the camera using the ACC wire and ground. The end of your camera's BATT wire should be wrapped in electrical tape since it is not used and you won't have the parking monitor feature activated. I think the camera's ground wire is either connected to the negative wire or ground it by securing it to a bolt (not sure so you should test it both ways, or wait for someone to give better advice). And make sure your INT2 switch is switched on...then the mirror will only work when the vehicle is on and when the switch is on too.
