- Local time
- 11:25 AM
- Joined
- Jul 26, 2022
- Messages
- 638
- Reaction score
- 1,626
- Location
- Toowoomba QLD, Australia
NopeI just bought the WolfBox G900Pro and the power source is a cigarette lighter. I'd like to wire in the right footwell similar to your set up. Should I cut the cigarette lighter and hard wire?
The cigarette plug is a 12v to USB-C 5v adaptor. If you cut the plug off and wire the cable directly to 12v you'll likely damage the mirror which operates on 5v not 12v. Someone else on the forum did exactly that.Yes, I think you can do that.
Your choices are either buy the Wolfbox hardwire kit, or buy a cigarette socket from any auto parts outlet and wire that to a 12v supply at the cabin fuse box or via INT1 or INT2. Then plug the provided Wolfbox cigarette plug into the socket.
The hardwire kit is the neatest solution and also provides battery low voltage protection (at 11.6v) if you enable the parking camera option.
