WolfBox - As A New Vendor, Offering 20% Off Discount!
Pfk
7:56 AM
Dubai, UAE
Does the Wolfbox function as a traditional mirror, or only has a camera display?
This is important as the clamp on design allows you to remove it if it fails. I would like to have a permanent adaptor if the Wolfbox also functions as a traditional reflecting mirror.
It does not function as a mirror
You would need to remove the clamps and use your mirror.
Edit: thanks to another member making me discover the off button it does function as a mirror, however somewhat dark but still ok to get through
Rab
3:56 AM
N.Ireland
You will find it does function as a mirror. That is why there is the option of the reverse wire connection so the camera only comes on in reverse and you use it as a conventional mirror the rest of the time.
Pfk
7:56 AM
Dubai, UAE
If it does function as a mirror, it’s a bad one at best. I have the g900 installed and the mirror effect when it is not functioning as cameras on is a reflective glare. I’m not sure how to activate the mirror you are referring to
FlyersFan76
10:56 PM
West Chester, Pennsylvania, USA
It functions as a mirror when you hit the power on the button on the bottom of the mirror.
chrsbe
4:56 AM
Sternwartestraße, Wien, Österreich
1) when installing the usb adapter via piggyback fuses in the fuse box under the ignition key. Why is there an additional permanent 12V source needed? It's obviously not needed with the cigarette adapter because this plug is dead without ignition.
2) how much power is drawn when ignition is not turned on? Will our wolfbox mirrors drain our batteries like vampires drink blood over night?
Clark Kent
1:56 PM
Toowoomba QLD, Australia
The +12v is needed to enable parking mode so the cameras can record when the vehicle is unattended. The cigarette adaptor doesn't support parking mode.
The hardwire kit has low battery voltage protection. The cameras will shutdown after 60 seconds if the battery voltage drops below 11.6 +/- 0.2 volts in parking mode.
10:56 PM
Florida, USA
Does anyone know what the best way to remove the stock mirror from the ball joint. Is there a tool or a release clip. I have the wolf box adaptor to use the current US spec mount but I don’t want to damage the old mirror in case I need to use it again.
FlyersFan76
10:56 PM
It is in this thread somewhere. Need a screwdriver to pry the black metal ring away.
BD1
9:56 PM
Illinois
Apologies I have not read thru this entire thread....is it possible to make this OEM with wires tucked away/wrapped, etc.? A lot of pictures I see show it with a lot of wires. And it does look like from the post above that you can remove the stock mirror vs strapping the wolf box on the factory mirror which is nice.
BD1
9:56 PM
Illinois
You can tuck the wires away but you will see the USB and camera cables coming out on top of the Wolfbox.
Any pics? Or I can read thru this long thread if there are some there. I see some online but not for the IG. Thanks.
chrsbe
4:56 AM
As you can see on the image. The cables are almost not visible. It is mounted over the existing mirror. You don't see rubber bands on the bottom when using a proper mounting arm.
Reactions: BD1
flynnsk
9:56 PM
Chicago
small flat edge should easily 'pry' the ring enough that it pops off.
parb
7:56 PM
Silicon Valley, CA, USA
I used the hardwire multifunctional kit. I think it allowed me to set up when to shut off power, i think the default is 11.6V but i think i set it slightly higher.
The slick part is that it turns off the display if the power is off after a preset amount of time. It wakes up the display of it senses G forces (like slamming a door). It actually works really well and i am sure that the most power hungry part of the circuit is the display.
I have had mine parked with wolfbox powered for 2 weeks without any discernible loss in battery.
WolfBox
Supporting Vendor
11:56 AM
LA
My dear friends, the G900 Pro is ready for pre-order in the UK market. Have a look at our website on the home page.
Pre-order for the G900 Pro
Preorder Only:
£65 OFF
for Extended Pack,
£40 OFF for Basic Pack.
End on Oct 31st
Auto Discount at Checkout
Your package will be mailed out on Nov 1st.
9:56 PM
Dallas
Hi @Mena2, the right footwell wires are connected to INT2 of your overhead panel and that switch is powered only when your truck is switched on (ignition at ACC). So you should wire the camera using the ACC wire and ground. The end of your camera's BATT wire should be wrapped in electrical tape since it is not used and you won't have the parking monitor feature activated. I think the camera's ground wire is either connected to the negative wire or ground it by securing it to a bolt (not sure so you should test it both ways, or wait for someone to give better advice). And make sure your INT2 switch is switched on...then the mirror will only work when the vehicle is on and when the switch is on too.
I just bought the WolfBox G900Pro and the power source is a cigarette lighter. I'd like to wire in the right footwell similar to your set up. Should I cut the cigarette lighter and hard wire?
AndyT
7:56 PM
San Diego, CA
Yes, I think you can do that.
