Front drive shaft broken
Has anyone here tried the Teraflex CV replacement, 175000 I saw it was drop in replacement from Align, https://teraflex.com/jl-jt-factory-replacement-cv-joint-kit-high-angle-rzeppa.html
just saw this after posting "I'd like to share valuable information about front drive shafts: the Jeep Wrangler JL/JT front Rzeppa CV joint is a direct replacement for the Grenadier front drive shaft CV joint. I plan to install and test it on my Grenadier to confirm fit and function, even though I've had no issues with my front drive shaft. Let me know if you have any questions."View attachment 7870191View attachment 7870192View attachment 7870193
You grab these pictures from John Brindell's install at Agile Offroad?
Yes since people had not seen, I now have one on Order now.
I sent note to John last night asking the flange was different. From John Brindell "Gregory Stoner it appears to be identical to the INEOS part"
Make me wonder if Teraflex is soucing these. now if we can find the source we not have to pay the markup, they are $189 at Teraflex, on sale on Amazon right now $161 https://www.amazon.com/dp/B0CKKD9BJ4?tag=globalgrena0b-20
there are multiple model on Teraflex site the correct Part Number is 1745000 is the one that been tested. I going to keep spare in my kit.
Who wants to go first with a cut and turn on the axle housing?
I did my fj40 20 years ago….. I’ll give you my address for shipping me your stripped housing to experiment with.
Seriously though. This all goes back 6 months to the castor discussion. We knew then the axle was designed odd considering it utilized cv’s. The solution is two dc joints. I suspect they will sell well.
It’s only one of the half baked design choices on this truck, but, the truck was never intended to rock crawl and this is solvable if you want a lift. Hell, a well designed lift with shocks for increased droop and adjustable arms still hasn’t hit the market, and that typically entails drive shaft mods anyway. I feel much worse for people having Hvac issues.
I am know looking at Mammoth Rzeppa CV Joint Kit to see if will also work, note the difference placement of flange and diameter. But trade of dust seal is more exposed.
https://www.mammothoffroad.com/prod...zIu7chU5lheUKIWutA_aem_K4HryXeRclPstSuT3B6OMw
Yep, On Caster, Metalcloak is comming out new control arms that are adjustable. FJ80 also had issue when lifted. I think you see once more truck are on the road we see more vendors will show up to solve few of these issues.
Why do all this whilst it’s under warranty and risk voiding the warranty. For me with world travel as the main reason I purchased the Grenadier, my mantra is keep it simple and as close to stock as possible. Sourcing parts that match aftermarket upgrades when half way around the world would be problematic
I just looking at having Trail spare ( the CV) with me when I am running around Moab and Southern Colorado as precaution, like you I am not put new springs on the truck and waiting until my K02 wear out before I put new tire on the truck. But I blow through the warranty period pretty quick with kind a driving I do here in the states.
Curious if a driveshaft rebalance would be needed after switching out the stock CV joints to the Teraflex ones? But if it’s only a spare for a trailside repair at least it would get you home.
The obvious reason, is your being a 1%er when it comes down to it. Notice all the “what tires are those?” And “what wheels are those?” Comments? Here it’s 95% looks, 5% Moab.
Angstorms, thanks for all your help.
No problem, really want to help out where I can. At least we now know this piece is shared with Jeep community same CV that on JL jeep. Make sense due to Magna involved in both projects, I am assume was primary designer of the CV joint.
Now if you lift your truck Jump over and read the forums for Jeep owner they also run into the same issue of boot wear on this CV. Most people who lift there jeeps end up with double cardan drive shafts, for us how stack stock this is now just another part we need to watch for wear like you do on Jeep and service.
Maybe will we get to point where Tom Woods custom drive shafts or many of the other vendors like Adams and have off the shelf drive line people just order to upgrad their drive shafts if they going to lift the truck.
Here is a quote from Tom's drive shafts page when they see issue on the Jeeps. Tom Woods Address in Ogden, UT
"Jeep JL front drive shaft noise. . . it is a common problem and is inevitable on nearly all lifted Jeep JL Wranglers. It comes down to the design. The stock drive shafts use Rzeppa CV joints that were designed to work in stock Jeeps. Two or three inches of lift is enough to cause these CV joints to fail (watch video below). JL drive shaft rebuild kits just don't cut it. That is why almost all JL drive shaft replacements are upgraded to a double cardan design (a double cardan is also commonly called a cv). This shaft will handle the angles that your stock drive shaft can not. The double cardan drive shaft is a time tested design that has proven itself in thousands of other Jeeps."
Just remember have fun, this is a great truck, it is not road queen it built to get dirty,
