Installed once I got home last night.
How are the surfaces of the steps attached?
The Perforated sections of metal where their logo is located are separate plates that are screwed on. Nice because you can remove to repaint if needed, or replace with a different tread pattern if desired. Smart design.How are the surfaces of the steps attached?
Will do this retroactively. Thank you!Before you tighten everything up, smear the section of the bolt that is inside the chassis with copper slip (grease) and also lightly coat the surfaces that touch the chassis.
Yes, copper slip slathered on the bolts (not the nykoc nut ones) and Fluid Film sprayed between slider and chassis mounts.Before you tighten everything up, smear the section of the bolt that is inside the chassis with copper slip (grease) and also lightly coat the surfaces that touch the chassis.
The main runner too?3mm thick high-grade 316 Stainless Steel. I can confirm non-magnetic.
Yes.The main runner too?
Powder CoatedAre those painted or powder coated?
It’s 23kg per side. We are a touch lighter than the OEM Rockslider option.Disregard…..just looked at the OK4WD site and it lists 100 lbs total!
FYI, ship weight is 125 lbs.Disregard…..just looked at the OK4WD site and it lists 100 lbs total!
If you have a roof rack, you can get a mounting-a-rooftop-tent-like workout heaving the box onto your roof.Also FYI, if you pick them up at OK in your Grenadier, you have to rest the box on the shoulders of the front seats to make the box fit and rear doors close.
