DaveB Vehicle Delivery
Status
Not open for further replies.
Given you're not close to your agent you could take it to a local tyre place to swap your rear wheels from left to right. If it's a wheel sensor issue the fault will follow the wheel. Pass on the result to your agent.
Unlikely that it is a wheel sensor given that it is simultaneously showing a "low tyre" warning (through the yellow indicator) and still showing the appropriate pressure
That's the idea of the simple elimination test. If there is no change to the error then 'unlikely' becomes 'not'.
And so Dave's thread has lost its navigator - and just look what happens.
Reactions: Rab
Now that sounds like a new job title for DaveB when he retires.
I have had the tyre pressure warning constantly from rear left tyre.
I adjusted tyre pressure until they were all the same and then reset the TPMS.
I left the vehicle parked for a couple of hours and then checked again.
Rear left tyre still alarming as low despite the fact it was highest of all 4 before reset and exactly the same after.
Rear right tyre was one in direct sunlight late in the afternoon.
Interesting I drove 31 kms from Hervey Bay to my place and it took 31 minutes.
Part of that was at 100 kmh and I also accelerated pretty hard away from the lights just to see how it responded.
11.6 l/100 kms is pretty good
Sitting in the car in back yard with motor running and aircon on after it had been parked in direct sunlight for a couple of hours.
took only a couple of minutes to get the internal temp down to 24 from 30 outside.
I get the occasional erroneous tyre pressure warning. I think it’s software related. Sometimes says tyre pressure is high on the wheel with the lowest pressure. 🤣 I’m confident that the software update will sort it out. 🙂
Status
