My wife had a door open when we were going around a corner. And there was no notice of the door not being “latched”The full narrative is at the link provided by Stu at post #1.
There has been reports made to the NHTSA about doors opening whilst the vehicle is in motion. The risk of injury was assessed as low (with the exception of your underpants) because the audible and visual alerts provide notification of an unlatched door.
Sweet. Looking forward to having mine done.I have to surrender the old set of keys, I believe they also need to update some system to link the new codes with my VIN number
its happened to a friend of mine here as well.My wife had a door open when we were going around a corner. And there was no notice of the door not being “latched”
Scary as f$&@
Can you elaborate more about the new ignition cylinder and a set of keys? How did you go about getting this done? And how long did it take to receive? I have been waiting for a spare key for three months…I had it done today in a dealership, and they replaced all 5 door lock buttons and ignition cylinder, I even got two new car keys.
Will see if this will actually fix the door buttons getting stuck all the time.
The difference is you are waiting for a key pre-cut to your existing lock cylinders and programmed for your vehicle; with the recall apparently it is just a fresh set of keys and locks that match the keyCan you elaborate more about the new ignition cylinder and a set of keys? How did you go about getting this done? And how long did it take to receive? I have been waiting for a spare key for three months…
Personally, I have a can of silicone in the garage and give it a spray every now again. As time goes on, I’m 100% certain the rubber washer inside will wear in. Having to change 4 doors is a very labouring job and the risk of trim clips and screws will go missing.I have the issue but lube it myself with a graphite spray. Question is do I keep doing that or have the dealer take things apart. My concern is they may create new problems or rattles. What do you all think?
Maybe you can cancel the order and get some cash back?The difference is you are waiting for a key pre-cut to your existing lock cylinders and programmed for your vehicle; with the recall apparently it is just a fresh set of keys and locks that match the key
Sound advicePersonally, I have a can of silicone in the garage and give it a spray every now again. As time goes on, I’m 100% certain the rubber washer inside will wear in. Having to change 4 doors is a very labouring job and the risk of trim clips and screws will go missing.
So you’re saying there is a difference in time, meaning the pre-cut takes longer to arrive. Well that sucks. Guess I’ll contact the dealership and ask about the new set. I have had zero issues with the door buttons and really don’t want them to mess with that.The difference is you are waiting for a key pre-cut to your existing lock cylinders and programmed for your vehicle; with the recall apparently it is just a fresh set of keys and locks that match the key
That's my experience too. Anytime my locks have stuck, I have been unable to slam the door shut.I have sticky door buttons. They have misbehaved ever since I spent a week on the beach at Fraser. The dealer “lubricated” them but after a while they started to stick again.
In EVERY instance where it stays in or partially in, it has been obvious and you pull them out so you can close the door properly.
And if it’s happened to my passenger, either they can’t shut the door properly, or the door alarm has come up on the dash or honked at me til I sorted it.
How someone could ignore all that and just continue to drive before going around a corner and having the door swing open is beyond me.
Perhaps I’m just clever I don’t know.
All mine were sticking, drivers side and rear door were the worst. Was concerning when the children were travelling with me.Mine Will be going in for its first service at the end of March and all the locks "stick in". I have been told that a are new designs/ replacements due in a few months and it will have to go back in for them to be replaced.
Lubing them up only lasts a few days on mine.
I missed it with a: SC6GM1CA5RF021XXX VIN. Build was Sep2024 IIRCAt over 7k units I think its pretty much everyone stateside.
Same. happened twice.My wife had a door open when we were going around a corner. And there was no notice of the door not being “latched”
Scary as f$&@
