A few questions about the Stereo System
lagartoboy
9:53 AM
Texas
I purchased the JBL nano from eBay for $199. I mounted the JBL in the center of the back seat and it fits perfectly. The factory plug is attached to the harness wiring, just feel for foam covering. There are M6 attachments in the floor, so I mounted two aluminum runners using plastic dowls over the SS screws to make it level with the seat frame. You need to be careful to mount the woofer, so it does not interfere with the parking break. I then used 2” Velcro strips to mount the JBL to the runners. It is easily removable and works perfectly. The only issue is tuning the woofer, for that you need to remove the front trim under the seat set the woofer and put is back in. All in all this is a 3 out of 10 in difficulty.
I don’t seem to have enough room to plug the factory plug into the woofer. Did you add extension wires to gain a couple of inches?
TRFAZ
7:53 AM
California, USA
If you follow the wires back, you can get more length by untapping them from the main harness. Its tight but totally doable.
Aussie Battler
2:53 AM
Apsley Vic
The Grenadier will play music from a USB thumb drive. It handles a variety of audio formats some including artwork.
More details in my manual. Download link in signature line below.
Cheers
Steve
I can get a thumb drive to work but that is all , had it for 10 months and still cant work the radio or the navagation system that was designed for mud crabbing
anand
10:53 AM
Maryland
What color where the wires and do you have any detail? A photo would be super helpful. THank you
The connector is taped to the center tunnel, on the passenger (R) side under the rear seat area. It is wrapped in black foam.
The easiest way to figure out the pin outs is to compare it to the plug on the BassPro Nano, I can't remember the speaker wire colors off the top of my head, but they match the colors at the speakers themselves in the doors
David Czarnecki
Supporting Vendor
10:53 AM
Statesville, NC, USA
Awesome man thank you. Glad we got to meet at Overland Expo East.
10:53 AM
USA
OK so ... my Dad actually bought one on Tuesday... (Hi again Pop...) - I was offered the chance to take it for a spin and I admit, it's a helluva truck ... But ... about that stereo ...
... a little underwhelming ... I'm going to have to play with the settings and maybe someone can help me out with the Subwoofer - what exactly am I looking for, people were complaining that theirs were either not connected at all or incorrectly configured (or not configured at all, switched off or something like that...) - So I have to take a look at that ... and the overall volume, so far I have to say that the much-maligned Bronco B&O premium system is much- much better ... FIRST IMPRESSIONS, again, have a lot more Research & Development to do. One thing the Bronco really shined was the sound of the system outside the vehicle. ... the Bronco AND B&O teams focused on designing the Bronco for both the DRIVE TO "The Party" and then AT The Party etc. So if you're at the beach and using your truck as the entertainment, it sounds great outside the vehicle, and it really did. The first time I had ever drove it, back in March of '22, I took it to the grocery store with the top down, parked it with the stereo blasting in the farthest part of the lot (scratches and dents less likely with no cars around etc.) - and went in ... when I walked out of the store, I tested the Remote Start, and it fired right up - and the music ... and people ALL OVER THE PLACE in each direction reacted like , "Holy ***** listen to that, LOOK at that etc." I will have to make a note to see how the Grenadier sounds outside the vehicle.
Anyway just curious what else everyone things with whatever time & miles & now months/years of experience everyone has with their stereos. Thanks again!
landmannnn
3:53 PM
One might suggest that the Bronco sound system is therefore designed for entertainment at beach parties.
That would probably suit many Bronco purchasers.
Arguably not the IG demographic.
10:53 AM
USA
Sorry if I sounded like I was interested in discussing Demographics.
In fact I was inquiring about the performance of the stereo system, and how to check if the subwoofer was connected properly - which is a known problem in the vehicle. Thank you for your concerns.
landmannnn
3:53 PM
Thank you for your passive aggressive response. Does daddy know you borrowed his vehicle?
10:53 AM
USA
He says to tell you that I since I bought it for him, I can borrow it if I want to. Although I'm quite content with my Jeep. She's the first & only female vehicle I've ever had, and really, all I need... and also to point out, that you must not really know the "Demographics" , neither, because since I've owned both, I am pretty sure I qualify as the "Demographic" ...
But back to the point, do you know or have anything to add about the stereo & subwoofer connection/settings? Or no? Just chiming in to be, like, you know, rude and not-helpful while at the same time calling me "passive-aggressive" (have no idea wtf that means...)
GN4HIR
9:53 AM
Houston, TX, USA
Samson,
Here is a thread I did on the subwoofer settings.
10:53 AM
USA
Hey Gun4Hire,
Just wanted to say Thank You Very Much, I will study it and I very much appreciate it. It's funny - yesterday I had the opportunity to take it out for another spin, and I admit that I was (more than) a little underwhelmed by the stereo system - so as my old man and I were just checking it out a little, I said "Hey , give me a quick hand? Let's just check..." - and sure enough ... in our case, the JBL BassPro Nano subwoofer was PLUGGED IN physically, but not turned out! Just pushing the Auto Turn-On button immediately gave a Red , then Green , light to flash ... and I was like, Hmm.. it can't be that simple ... but AS SOON as turning the vehicle/stereo on, you could *immediately* hear, feel , and tell the difference. It's much , much better with it on. You'd think they would know to do that lol.
I will still have to mess with all the settings but it's nice to at least get that sorted.
I do wonder what type of power the other, actual speakers are getting ... I don't think Ineos will address it other than to say that the speakers are "powered by an integrated amplifier built into the main head unit" ... yeah ok, but when you get the Premium system, it specifically says "uprated amplifier" and the subwoofer itself is powered integrally ... it would be nice to have details. Plus they used probably the least-desirable choice of speaker sizes, would have been very nice to see the extremely-common 6"x9" but hey, nobody asked me lol.
Anyway thanks again Sir , much appreciated bruv.
RYAustralia
1:53 AM
North Queensland Australia
Thank you very, very much ZB - I very much appreciate your time & especially the info. I have read similar stuff. Sucks because why bother putting something "Premium" - in a $100K vehicle at that- that isn't actually Premium.
Thanks again let me think about it all please!
I just set up the factory subwoofer using the JBL bass test playlist on Spotify using the sub gain filter and bass boost screws. Sounds a million times better than the factory defaults which were so bad it was criminal.
Dual Grenny Guy
9:53 AM
Louisiana, USA
I don’t know if this post will answer anyone’s questions, and I’m not a tech guy so please don’t ask me any of those type questions.
FINALLY finished the exterior of my 1st Grenadier build recently, so now on to the interior and this week it was the stereo. Like many have said it does seem lackluster to the ear. I don’t expect or want a coliseum concert in my ride, but I do enjoy a loud song every now and again. I only listed to classic rock (AC/DC, Led Z., Skynyrd, VH, ZZ, etc) so don’t need the boom boom stuff just like to hear the words/music louder at times if that makes sense. Anyway, this Grenadier did have the stereo upgrade which we all know now is just a mini JBL pre-amped box. My stereo place advised I could change the speakers but the factory ones are actually pretty good and they suggested to just add a nice JL audio 4 channel 400 watt amp to the factory speakers and then they would adjust the mini box, which was turned so high from the factory all I could hear was the booming. Weird how most say theirs were turned off and mine was set to high. Guessing someone at the dealership may have played around with mine. Anyway, after doing this, wow this thing now sounds AMAZING!! Before I would turn the radio up to 12 on some songs maybe 13 as didn’t want to hit the 14 max limit and still didn’t have that nice loud sound I wanted. Now I swear I can barely get to 8 on the volume before saying that’s it!! Best $1200 I’ve spent on a radio improvement in some time. If I blow a speaker, which I doubt will happen as I’ve been blasting it all day, I will post about having to get new speakers. I’ve seen some on here post they tore out everything and put in all new speakers, sound proofing etc etc. which I have absolutely no problem with (see my blue exterior Grenny pics you will see how much I have done to it), but I didn’t want a $5-10k radio. This works just perfectly. Now on to step 2 of the interior, the rear cargo storage system……
10:53 AM
USA
Can I bother everyone with one more question? I don't want to make another thread and I couldn't find anything by searching-
Is there a way to display the current Turbo PSI boost on the display / Infotainment system?
On the Bronco - you could configure the Dashboard many different ways, including the Turbo PSI in a Large Display, with a circular graphic and numbers, OR in other ways, so it's displayed with other info and smaller #s - I can't find any way to do it on the Grenadier... is it at all possible to see? Thanks! To everyone, much appreciate the help. Still learning here.
GN4HIR
9:53 AM
Houston, TX, USA
I've never seen that one in the settings.
anand
10:53 AM
Maryland
10:53 AM
USA
OK Thanks everybody - I suspected as much ... I spent a while searching in the manual, and then sat down and just played with Infotainment System for some time and couldn't find anything - there really isn't all that many settings of anything to play with (and I'm sure Sir Grenadier wanted it that way) - just different ... my daily driver is a Jeep, and I guess the family car has been Jeep in my family like Sir Grenadier always had a Land Rover - and it's pretty basic really, but I've had it for a long time so I'm familiar. The Bronco actually had quite a bit to display/change/use - that was actually one of the things they set out to do ... it's my understanding they watched the mostly-disappointing roleout of the Jeep pickup truck and said, "We're NOT doing that - we want *everyone* to want one, and love it, from old-school Bronco owners to everyone else from kids, housewives, Soccer Moms, Doctors/Lawyers/Cooks-Bakers-Candlestick Makers to the Off-road Enthusiasts" - and IMHO they did it pretty well, got used to that system and I'm still trying to get used to this system.
And the reason I asked - I Googled it and saw that one place said it produces a surprisingly low Turbo PSI , like less than 5psi, ... so that sounds like, when they Detuned this thing, they apparently really Detuned it. I'm not exactly one of the Fast & Furious-types of dudes who are on YouTube with 700+HP Supras that they have put through surgery to be Rocketships etc. - but driving it does make me wonder what it's capable of. (And it certainly feels great - you can *feel* the BMW engine / German engineering / "Good Stuff" right through the pedal & steering wheel. IMHO of course.)
Thanks again everyone.
