A few questions about the Stereo System
lagartoboy
9:24 AM
Texas
I purchased the JBL nano from eBay for $199. I mounted the JBL in the center of the back seat and it fits perfectly. The factory plug is attached to the harness wiring, just feel for foam covering. There are M6 attachments in the floor, so I mounted two aluminum runners using plastic dowls over the SS screws to make it level with the seat frame. You need to be careful to mount the woofer, so it does not interfere with the parking break. I then used 2” Velcro strips to mount the JBL to the runners. It is easily removable and works perfectly. The only issue is tuning the woofer, for that you need to remove the front trim under the seat set the woofer and put is back in. All in all this is a 3 out of 10 in difficulty.
I don’t seem to have enough room to plug the factory plug into the woofer. Did you add extension wires to gain a couple of inches?
TRFAZ
7:24 AM
California, USA
If you follow the wires back, you can get more length by untapping them from the main harness. Its tight but totally doable.
Aussie Battler
1:24 AM
Apsley Vic
The Grenadier will play music from a USB thumb drive. It handles a variety of audio formats some including artwork.
More details in my manual. Download link in signature line below.
Cheers
Steve
I can get a thumb drive to work but that is all , had it for 10 months and still cant work the radio or the navagation system that was designed for mud crabbing
