A few questions about the Stereo System
lagartoboy
10:35 AM
Texas
I purchased the JBL nano from eBay for $199. I mounted the JBL in the center of the back seat and it fits perfectly. The factory plug is attached to the harness wiring, just feel for foam covering. There are M6 attachments in the floor, so I mounted two aluminum runners using plastic dowls over the SS screws to make it level with the seat frame. You need to be careful to mount the woofer, so it does not interfere with the parking break. I then used 2” Velcro strips to mount the JBL to the runners. It is easily removable and works perfectly. The only issue is tuning the woofer, for that you need to remove the front trim under the seat set the woofer and put is back in. All in all this is a 3 out of 10 in difficulty.
I don’t seem to have enough room to plug the factory plug into the woofer. Did you add extension wires to gain a couple of inches?
TRFAZ
8:35 AM
California, USA
If you follow the wires back, you can get more length by untapping them from the main harness. Its tight but totally doable.
Aussie Battler
2:35 AM
Apsley Vic
The Grenadier will play music from a USB thumb drive. It handles a variety of audio formats some including artwork.
More details in my manual. Download link in signature line below.
Cheers
Steve
I can get a thumb drive to work but that is all , had it for 10 months and still cant work the radio or the navagation system that was designed for mud crabbing
anand
11:35 AM
Maryland
What color where the wires and do you have any detail? A photo would be super helpful. THank you
The connector is taped to the center tunnel, on the passenger (R) side under the rear seat area. It is wrapped in black foam.
The easiest way to figure out the pin outs is to compare it to the plug on the BassPro Nano, I can't remember the speaker wire colors off the top of my head, but they match the colors at the speakers themselves in the doors
David Czarnecki
Supporting Vendor
11:35 AM
Statesville, NC, USA
Awesome man thank you. Glad we got to meet at Overland Expo East.
