My cables (VIN in the 1500s) are very firmly attached and I can't envisage them ever coming off ; have they changed the original clamps?$5 fix on the possible Bowden Cable issue, 2 x P Clamps and 5 minutes…
I was told my XHQ It impacts earlier cars, mine did not need to be done. I am chassis 7719.My cables (VIN in the 1500s) are very firmly attached and I can't envisage them ever coming off ; have they changed the original clamps?
As I said , mine's 15XX, It took 7kg of force (fishing scale) to pull the cables off.I was told my XHQ It impacts earlier cars, mine did not need to be done. I am chassis 7719.
My VIN is early 3000,s after nearly 30,000kms no issue but they are easily pulled from the bracket, so figured why not an easy preventative mod. About to do a few kms on gravel.As I said , mine's 15XX, It took 7kg of force (fishing scale) to pull the cables off.
Not the least bit concerned!
They must have changed their supplier.My VIN is early 3000,s after nearly 30,000kms no issue but they are easily pulled from the bracket,
Sounds like they chose the wrong sized clamp to me.My vin is 1163 and they were falling out easily before a modification was made.
nice. a little 12v ciggy socket pump is worth it when speed is needed.View attachment 7865677View attachment 7865677On holiday in France just now. Went for a play on the river, glad I had the roof rack as it was quite an effort blowing up the paddle board and the kayak. If we go again later in the week we I won’t have to do it again. Unfortunately i only have one ratchet strap with me!
I have the arb twin and an air tank! But alas no fitting for the kayak to connect to the compressor. It was lots of work with a foot pump.nice. a little 12v ciggy socket pump is worth it when speed is needed.
"....i can see you're right sir, the seams have indeed failed. talk me thru your inflation setup"I have the arb twin and an air tank! But alas no fitting for the kayak to connect to the compressor. It was lots of work with a foot pump.
August Pic Winner.Enjoying the alps between Italy and France.
On mine, bull dust come thru door handle on the 1/3 door and bottom side of the 1/3 door window.At Bramwell station today. Tiny dust leak at back door, seems to be in the top middle of the big door. Otherwise it's going brilliantly.
Old telegraph track tomorrow.
