Installed my Tougher seat covers and dash cover. Excellent fit and quality. I’m very happy with the customer service as well. They accommodated my request to put the logo patch on the rear of the headrests and I think it turned out good. I would recommend their products for anyone shopping for seat covers. 👍
Just moved the Grenadier off the drive, so I could take the Morgan down onto Melton's Market Place.
Once down on Market Place, I parked next to an AEC Matador. During the war these were used an gun tractors, (usually the 5.5" gun), post war as recovery vehicles and logging tractors. This one dates from the mid '50s and the bed is modern.
Today I decided to check and test the winch. Pulled out the line in free spool, a bit stiff but did it ok and pulled out to the red marker. All good so far. Turned the remote on and full green light. Green light also flashing as it should when winch in or out is pressed. Vehicle in neutral, hand brake on , 500a switch on overhead console on. Winch lever in verticle/engaged position. Nothing working. Re-paired the handset and tested power at the 150a breaker under the bonnet, all good. Still not working. The solenoid can be heard clicking in when turning on the 500a switch and I have power at the NATO plug at the rear.
Anyone that has ideas please. Winch line out on the driveway and I’m off for a walk withe dog until someone can help me figure what’s wrong.
Thanks in advance. 👍🏼
Bit odd that. Would try a few variations, offroad mode, handbrake off, in drive etc
I would love to help you. But I don't have a winch myself and therefore unfortunately have no experience to pass on to you. Sorry mate.
I assume the car is on, since you say it is in neutral? Car must be running.
Pulled out the line in free spool, a bit stiff but did it ok and pulled out ...
In my case it is very very stiff. I usually put the lever in horizontal position (free spool) and pull the line out with the help of my remote.
But this doesn't help you in your diagnosis. It seems you checked all evident stuff!
Still two ideas:
  1. replace the batteries of the remote, perhaps enough power to pair, but not enough to send the continuous signal to "winch". (but I guess this will not help)
  2. remove the protection plate (I forgot the name used on the forum: skid plate?) under the car and check the connections of the winch
Beware that putting the protection plate back is not that easy, especially, as is perhaps your case, if it is slightly bent.
Well I’ve tried everything besides taking the protection plate off but can’t get it to work. Changed batteries in hand set, tried handbrake off and in neutral with engine running various combinations but no luck. I’ve never used it before apart trying it on my driveway after I first bought the vehicle.
Luckily there is enough room inside outer plastic bumper to store the rope until I get around to getting it checked out
at the Ineos garage.
Last couple of weekends have been busy. I'm now mostly done with most things I wanted to do.
Here we go..
Better mounts for my ARB side lights. Found these on amazon for cheap and they work great.
Relocated the gmrs radio antenna to the roof rack. I have a tall antenna for being in he country side, this is for daily use.
Got my bullet point cell phone mount, gmrs handset mount and tablet mount installed on a eBay bracket out of China. Really, really stable. Added a USB power source in the passenger footwell tie wrapped to a wire bundle on the left side of the footwell. Pulled power from the int wire on the right side of the footwell. That also powers my gmrs radio and my weboost + the USB socket. I may blow a fuse if I pull a lot of power on all three at the same time but I should be okay.
I love that mount. Really happy with it. I get very little blockage of aircon or instruments.
I installed the linear 42" light bar from triple-R lights. UK brand and made in the UK. Really, really good control of the directivity of the lights. Can't wait how they will work with my Baja 80 lights in the grille. Can't adjust them until it gets dark but I think it's going to be awesome based on the daylight tests I've done. 24.3Amp draw and just works on the roof rack. I extended the wire harness and ran it in a rubber channel I installed in front of the first bar.
I added a relay for the chase lights and I also have the relay controlled by one of the switches up front. I had to add diode protection to prevent backfeed. Red-Orange is the reverse light wire. Took power from the battery side of the 500A relay (and fused it at 5A).
Finally, some vanity... I installed a decal from my favorite race. 😁
Luckily there is enough room inside outer plastic bumper to store the rope until I get around to getting it checked out View attachment 7865844at the Ineos garage.
@Wile E Coyote had a problem with the control box which he rectified, I'm sure he'll comment with the solution
