Vehicle mounted twin air compressor
Shopkeep
4:31 PM
I watched the video again and it looks like there isn’t room under the seat for tank.
-Can you attach a small tank inline with the 1/4NTP(?) fittings as an ad-hoc add on when using tools? Just make that part of the tool kit?
Maybe you can fit a thin air tank in the rear footwell, mounted on the back edges of the seat brackets (something like the TJM 5 litre.) Depends how often the rear seats are occupied, I have a Maglite 6D mounted there which is a bit longer but is not intrusive.
MileHigh
That Guy
2:31 AM
Colorado
Just put an air tank under the body between the frame rails.
I was starting to wonder about that. Are there pre-existing holes you can re-purpose ?
For this mount, getting the seat out of the way doesn’t seem that bad- but how often does an ARB twin need maintenance?
2:31 AM
Colorado Front Range
I have not investigated in detail an under body mounting location for an air tank. But a small one gallon model like that sold by ARB should be quite easy to find a location for. I have done this on my other vehicle which is a Jeep. I like having a tank if only because it acts as a buffer in the system, reducing the amount of on-off cycling by the compressor. When I get around to installing a compressor in the Grenadier the first place I will investigate for the air tank is the location used for the urea tank in the diesel models.
MileHigh
That Guy
2:31 AM
Colorado
How far from the pumps can the tank be? I assume a few feet doesn’t matter?
2:31 AM
The distance between the compressor and the tank is not an issue. In the setup on my Jeep the compressor is under the hood (an engine driven AC style compressor) and the air tank is mounted above the rear axle on the underside of the body. The air line connecting them is approximately 8 feet.
4:01 PM
South Australia
I thought of using the oem rock sliders as an air tank. Just need to check if they are tight.
The OEM rock sliders have drain holes in them.
But for the air compressor location it is easy to mount 2 ARB air compressors between the chassis, sill panel and rock sliders as I have done, ARB compressors are waterproof as long as the air intake is higher than water level.
I have the air intake, air outlet and switch, and power supply under the bonnet, no holes drilled, I did that in the first week of ownership.
I made a bash plate for the compressors, and they mount higher than the bottom of the chassis and rock sliders
There are pictures in the thread steps added to rock sliders.
ARB used to advertise their air compressor in a fish tank with a raised air intake, and in one Adelaide ARB store they told me they had the same compressor in a fish tank on display for a couple of years, and it still worked.
