I completed my dual ARB install under the rear seat. Since I had a lot of space it wasn’t that difficult. I stood it on end and it was just the right height for the seat to go down all the way. I was visualizing a mounting bracket/plate in my designer head when I realized that if I rested it on dense foam (neoprene) and applied similar foam to all points of contact with sheet metal, that I could hold it in place with large strong cable ties. I use cable ties for a lot of applications and the thick ones are plenty strong. So the compressor is sort of ‘suspended’ yet well contained. I put the switch and output right in the panel under the seat. I cut the harness way short (one foot long) since the electrical sources were very close. Without sheetmetal contact, it is quieter and doesn’t transmit vibration to the vehicle. First test and it worked fine. See video.
