Tool pornHere’s my 1/4” wera set. View attachment 7811437
+2 for Wera and Makita+1 for Wera
+1 for both+2 for Wera and Makita
It definitely looks like that.I find that style have a tendency to roll off the nuts when applying real force.
If I ever spotted you working under your truck with your feet sticking out, those boots would be all mine.Thats the tool kit I found under the seat the double ended ring spanner was in there plus a couple of Allen keys and a two ended screw driver the wheel brace handle doubles up as a Jack handle
View attachment 7797696View attachment 7797696
I can vouch for Makita as have a very comprehensive array of Makita battery kit for work and also the brushless motor hammer drill and 1/4 impact wrench at home for DIY. My battery circular saw has taken a real beating and still going strong. I’ve previously used Hitachi tools but don’t think they are available any more or maybe changed names.I love the Makita stuff as well. I even have their radio . But even the radio is top notch. DAB, FM, perfect reception. Internet Radio and podcasts as well, WLan. Stunning sound, fat bass, if you want (equalizer).
I use a battery screwdriver which is powered by a brushless motor. More Power than I need and most importantly short construction which help in tight corners, And I never thought that a battery angle grinder is worth anything. Until I bought one from Makita (couldn't resist). A excellent all purpose tool on any trip.
I do however not see a reason for extra high torque in daily use: To loosen a very thight nut I find an extension better. And if s screw or a nut is loose, the extra torque is not needed any more.
What I can recommend however is this thing, it's a hammer of a tool. Makita. (of course). The DWR180Z:
At the latest when you only have a 5° working angle for a ratchet or wrench, you no longer want to do without this thing. No need to talk about the quality: perfect. When I bought it last November it cost just 121€ which is a just a bargain.
I have the same one in my work setPanasonic was once good as well. But they seem to be out of the market.
As to the angle grinder, it's the DGA452:
Metal gearbox, brushes easy to change (although they will with my using profile likely last longer than I will).
Now I’ve got tool envy. I must admit I’m a bit of sucker for tools and kit. I’ve just had a Machine Mart catalogue through door, that’ll keep me occupied for days drooling over thatI will see your 1/4" set and raise you my 3/8" set
The brushless kit seems to have so much more powerAnd to make it complete, I looked up the model number of my screwdriver. It's the DHP485. Very compact.
Someone showed their Wera wrench set here a while ago, after seeing that I went deep, deep down the Wera rabbit hole. If you bide your time and know your product there are amazing deals to be had on Amazon.Now I’ve got tool envy. I must admit I’m a bit of sucker for tools and kit. I’ve just had a Machine Mart catalogue through door, that’ll keep me occupied for days drooling over that
It does. And when you press the button to full power, it's almost immediately at full speed and gives an unpleasant backlash at the wrist. When you let go of the button, it stops within a fraction of a second. Very impressive response.The brushless kit seems to have so much more power
