rattle in LHD drive side
2:10 PM
Denver, Co
new IG with less than 300 miles.
Driving over washboard road at speeds of around 20-25mph results in a metallic / hollow sounding rattle above the driver-side footwell region. Driving at any speeds on pavement does not trigger this rattle.
Anyone else experience something similar?
One possibility is the heat shields rattling under the car. My rattles were intermittent and unpredictable. Three of my heat shields were readjusted and the rattle disappeared. Your description is close to the rattle my heat shields caused.
I also found my jack loose in the rear quarter and tightened it as well.
You just need to work your way through the possibilities.
Where are these heat shields? In the engine compartment or under the vehicle?
I do also have heavy metal clunk in the back going over these washboard roads
Down under the vehicle along the left side. The dealer fixed it and did not say exactly where.
That heavy clunk maybe a loose jack.
Take a close look at the areas in the photo. I bent my sheet metal back then. It's been quiet ever since.
