I’m only aware of some spare mini fuses in my GrenadierDo you know if the vehicle comes with replacement fuses?
Certainly not spares of each fuse type, but note Logsplitter's comment.Do you know if the vehicle comes with replacement fuses?
They’re in the forum resources as well.The US Owner's Manual has more information on fuses and fuses boxes, than the previous hands out in other countries. It can be downloaded here. As it is a US Manual do not assume a non-US car is the same, but they do seem to have a lot in common. Look at page 194 and following.
It has extra information on other topics as well.
The Grenadier will be using ISO type relays this system is based on the Bosch standard. As a suggestion also include if the relay is a make, break or change over relay with resistor or diodes. Cole Hersee (Littelfuse), Hella, Delco, Narva etc may be the only brands available at some retailers in some regions. Bosch does have some cross reference literature back to OEM part numbers but unfortunately Ineos has not been added.Some Relay information has been added to various posts. I do not have INEOS Part numbers despite asking.
It has been suggested to me the Relays in the Grenadier are Bosch Relays. This is only a DRAFT Table, everything needs to be confirmed:
Thank you to my source, who wishes to remain anonymous.
In my opinion the description and amperage of FL03 and FL04 should be switched. In the "very famous"Diagram added to the post for the High Load Auxiliary Switch Panel option. Thanks to my source that wishes to remain anonymous.
I pointed that out to the source, but they explained why they left it that way.In my opinion the description and amperage of FL03 and FL04 should be switched. In the "very famous"picture that @DCPU posted and that I amended with fuse legends, the 5A fuse sits in position FL04.
See the picture here: https://www.theineosforum.com/threads/main-fuses-used-in-ineos-grenadier.12411958/#post-1333181794
So, what is the explanation?I pointed that out to the source, but they explained why they left it that way.
@lollo05068: Wo kann man das Kit kaufen?Now, hopefully, good prepared. Thanks @TheDocAUS for all investigation. View attachment 7840127
Amazon, no Kit, two or three single sets, and an empty IKEA box@lollo05068: Wo kann man das Kit kaufen?
Hello,WINCH FUSE
INEOS Australia today stated the RED winch circuit has a MEGA fuse (Midi style) rated at 400 amp for the 350 amp winch circuit. Others have said 250 amp fuses x 2.
The other way we can resolve this is for each owner to see what is installed in their car.
RELAYS
INEOS Australia has not yet confirmed spare relays are available from the Melbourne Warehouse (I asked).
It was a painfull (for my hands) operation, but I suceeded. I removed the 3 bolts fixing the colant reservoir above and removed the two coolant hoses left and right to be able to lift the reservoir just enough to unlatch the yellow clips and peek into the box with an endoscope camera. The two fuses (2-Seater Utility with extra battery, high load switch and front winch sold in Germany if that matters) has got two 125A Mega-Fuses inside.I have not seen it. We need a photo with the lid removed to see the actual fuses. I am not aware of any manual for that fuse box at this time. The sticker is getting ahead of itself.
Great that you've been able to visually confirm the fuse ratings for this box @bnebenda.Hello,
I might have missed it, but I never saw a clear statement regarding the fuse rating of the Winch Fuse Box located under the bonnet
No is the short answer. I could only find a complete 5 stud or 7 stud busbar.
