Torque settings - various
Our oil drain plug is plastic and 8nm. If doing an oil change, you need a new one.
CAUTION: Now in good shape but not perfect. If you are unsure speak to your mechanic or installer.
TORQUE SETTINGS
This post is a place to post torque settings for various parts of the INEOS Grenadier. I will add more as I find them, but feel free to post any settings you know.
You can convert Newton metres (Nm) to foot pounds and vice versa here.
WHEEL NUTS
Steel rims 180 Nm.
Alloy rims 160 Nm.
Spare tyre on back: TBC (but 120Nm has worked for me on other cars, but I check regularly when going remote).
Source here. Thanks to @Steven Cook
The US Owner's Manual, on page 130, only gives one figure 160 Nm. Not 160Nm for alloy and 180Nm for steel rims.
WHEEL STUD SIZE AND THREAD
Wheel stud size and thread is M14x1.5 (Source here).
TERMINAL SCREWS/NUTS ON CTEK UNITS
Use a 5mm Allen Key on the terminal screws (nuts) and tighten to 8 Nm/71 lb-in of torque (see Figure 2 on page 6 of the CTEK Manual). Tightening by hand is not good enough, as the connector plates and cables will come loose.
The unit itself can be secured using M4 or ST4.2 screws or bolts, in each of the four corners. The screw or bolt is torqued to 2 Nm/18 lb-in (see Figure 1 on page 6 of the CTEK Manual).
FUSES
Three factors seem to come into play when determining the torque settings; the fuse holder, the fuse type and the stud size (for MIDI and MEGA fuses). Read any instructions and follow any recommended torque settings if provided. Otherwise read on.
Z CASE FUSE NUTS ON 5 AND 7 STUD BUSBARS USED ON MAIN AND AUX BATTERY
Note:
the busbars used on the INEOS can have M6, M8 and M10 stud size. Both the 5 stud and 7 stud versions have a mixture of stud sizes, depending on the circuit rating. The higher the circuit rating the bigger the stud. You must work out the stud size and torque accordingly. The busbars can vary between models, so you need to look at each stud size before you torque them down.
In summary the torque settings are:
M6 studs
No torque setting is given for the M6 studs in the busbar manual. However, the ZCASE MEGA fuse Manual gives a torque setting for M6 studs: 9.8Nm±1.4Nm or 8.4Nm to 11.2Nm.
M8 studs
Studs that are M8 can be torqued to 14Nm±2Nm, or 12 to 16Nm. However, the ZCASE® FHZ Series busbar manual states that the M8 Mounting Torque is 12-15Nm (a slight variation). Both agree between 12 to 15Nm. FHZ manual here. Relevant extract here:
Warning: these are the suggested torque settings for the Littelfuse busbars with M8 studs and Z Case fuses used in the INEOS Grenadier.
M10 studs
16Nm±2Nm or 14Nm to 18Nm for M10 studs. Source: Littelfuse FHZ Instruction Sheet here (page 2).
Additional information: the ZCASE MEGA Fuse manual states: “The fuse design is optimized for a one bolt connection M6 (40A - 250A) or M8 (300A - 600A) and can used directly on a battery post or busbar connection.” Suggesting you do not need any M10 stud even tough the busbar can be fitted with one.
Tip: the torque setting appropriate for fuses can depend on what fuse holder they are being installed into. First check the manual/instructions guide for any suggested torque settings for that fuse holder and fuse.
Hi, Does anyone know the following Tork size drivers & torque setting for the following fasteners.
The door hinges screws, which I believe are just tork and not Tork +.
The bracket screws holding on the aluminum grab bars up at the roof. I believe they are just tork and not Tork +.
The exterior airline utility rails. I believe they are Tork +.
DaBull
DaBull
If no one answers I get my car back tomorrow and I can help you then. I have posted the door hinge Torx size somewhere on the board. If I find it I will post the link. EDIT: Found it here.
My external facing door hinges are Torx T50 screws/bolts.
I do not think the US Spec car and AU Spec differs on that point. Tip: I saw some where they placed some plastic over the Torx head socket to minimise damage to the paint on the torx screw in the hinge.
The different heads
Source
DaBull
Da Bull
1. Door hinge is a Torx T50 head;
2. Bracket screw on roof grab bar is Torx Plus 25;
3. Exterior utility belt bolt is a Torx T27.
The Security Torx bit T30 will also works (I think that is your Torx+).
I used 3 different Torx T30 sockets and they all fitted items 2 and 3. Two bits were from my WERA set (the T30 and the T30 security torx) and the other T50 was a no name brand from Taiwan.
Main kit I used to determine size was this:
Da Bull
2. Bracket screw on roof grab bar is Torx TX30 (using WERA Torx head socket);
3. Exterior utility belt also uses a Torx TX30 (using WERA Torx head socket).
The Security Torx head T30 will also works (I think that is your Torx+).
I used 3 different Torx T30 sockets and they all fitted items 2 and 3. Two sockets were from my WERA set (the T30 and the T30 security torx) and the other T50 was a no name brand from Taiwan.
Hi TheDocAUS,
Thanks for the torx bit sizes. I appreciate it.
I did some esearch on Torx Bits and it turns out there are 3 primary types.
T or TX, which is the original type invented in 1967.
T+, which is an improved version invented in 1990.
Both also come in a security type which has a hole in the end of the bit and a pin in the middle of the screw.
As the linked video explains, a T or TX bit will fit both types of screws, (T or TX and T+), however
a T+ bit will not fit a T or TX screw.
Here's a good video to explain the difference. DaBull
View: https://www.youtube.com/watch?v=U27j1ZvaWeU
Any idea on torque settings for the utility belt?
Mine didn't come with it and I'm buying it as a part.
Hi TheDocAUS,
Thanks for the tork bit sizes. I appreciate it.
I did some esearch on Tork Bits and it turns out there are 3 primary types.
Based on that video my Torx head socket maybe going into a Torx Plus screw/bolt and it will not be that obvious. Looks like I need some Torx Plus bits and retest. Only them can I work out which is which.
Items 2 and 3 remain open.
EDIT: Torx Plus bits are not easy to get in Australia, had to source them out of the US.
I have not seen a torque setting for the utility belt. I try and add known Torque settings to the first post when I do. Keep looking.
Update as the Torx Plus sockets arrived.
The Grab handle bolt is a Torx Plus 25. The door hinge bolt a Torx 50.
The utility belt bolt is still a mystery. The Torx 25 fits, bit it's loose and the Torx Plus 25 does not really fit (it gets stuck). I am thinking it might be a Torx 27, but I cannot find my Torx 27 bit. Pretty sure I have one, it must be in a smaller set of bits - not my main set. The search continues.
Hi The DocAUD, Many thanks for the update. I just received my Torx + bits and am ready to go at it and have some fun!
Leitner Rack Install - Torx Plus 25 per @TheDocAUS
Buzz Overland Hinge Steps Install - Torx 50 per @TheDocAUS
Keep the info coming. I ready for more Fun! DaBull
The best fit for the Utility Belt bolt was a WERA Torx T27 bit. I found the T27 bit to check.
I edited my post above to correct the sizes.
I started a new thread here on bolt head types. I added info you and I have been discussing.
MIDI FUSE
Tip:
For the single MIDI fuse check the stud size, it will be M5 or M6. The torque settings are (if you use 5Nm or 5.5Nm for either stud you should be OK):
Source here.
MEGA FUSE
Tip:
AUX BATTERY
For the single MEGA® SN Series MEGA fuse holder used on the aux battery, the recommended torque settings are:
Note: I believe the IG uses M8 bolts not M6, but check, source here:
FACTORY INSTALLED RED WINCH
The Winch appears to use the HPDM Series - 70 V Max 600 A 2-Pole MEGA® Fuse Power Distribution Module, in which there are MEGA fuses. No torque setting is given, so I would use the recommendation for the aux battery MEGA fuse, being 12-18Nm. The same torque setting is given in another MEGA Fuse manual from Littelfuse here.
TOOLS
I have one torque wrench suitable for higher torque settings for wheel nuts, etc. and a second for lower torque settings (2-22Nm) for the fuses, CTEK units, screws, etc. Bike torque wrenches seem suited to these lower levels of torque; they are also often smaller than a full size torque wrench which can struggle to get into tight spaces. Tip: I choose a 1¼ torque wrench, as my smaller wrench, because it was compatible with other 1¼ sockets, torx heads, screw driver heads, etc. I owned. For others a 3/8 torque wrench maybe more useful.
OIL FILTER CAP/OIL FILTER COVER
Torque setting is 25Nm (Source: Joey and Stu Barnes).
Labelled 1 on the following diagram (Source: Clark Kent).
OIL SUMP PLUG
Torque setting is 25Nm (Source: Stu Barnes).
DONALDSON AIR INTAKE PRE-CLEANER
Torque setting for the Donaldson Cyclone Art Intake adapter nuts is 10Nm. Page 6 of the INEOS Fitting Guide. In turn the Cyclone Filter goes onto the Adapter and is held in place by a clamp. This is no recommend torque setting for the clamp.
GUTTER MOUNTED PIONEER PLATFORM ATTACHMENT POINTS
15-17NM or 11-13 LB/FT, INEOS Fitting Guide here. Tip: read the Installation Guide as there are various torque settings for different parts of the roof rack. Only one is shown below.
FRONT AND REAR DIFFS
Torque to 31Nm. (thanks @Ragman)
TRANSFER CASE
Torque to 15Nm. (thanks @Ragman)
SUSPENSION AND STEERING TORQUE SETTINGS
Details posted here. Thanks to @Guardian
Fantastic information
Table updated to include Oil sump plug size and thread pitch, same for the wheel nuts. See Comment column.
Excellent work, very useful information. Could you post the link for the more comprehensive list as the link in the attachment does not work. I tried searching but came up empty handed.
The Table is an image which is why the link is not working. The Table is going into the Rok Dr Guide, probably the next update with a link that works.
That link is to the start of this thread, as the Table is just summarising some of the info in the thread.
