CTEK SMARTPASS 120S and 250SE DC to DC charger basic features and install information
I have been away a few times with only a watt/current metre on solar panels and a votage metre on the second battery to determine battery health, which to be fair has worked well as I've never had a problem, but I wanted a more detailed way to monitor battery health status.
I installed a simarine unit including a quad shunt for accessories power use and a main shunt for battery monitoring.
When over drawing one night (due to overloading the fridge, turning it up, and forgeting I had) pulling the battery down to 38% I started the car to boost charging and saw over 100 amps being pushed back into the second battery from the 120/250 combo. (Other than the 250 being added, it is wired as Ineos did it) Clearly this system does work and can work well. Having used it for a bit, i am not disappointed.
I have wired my installed accessories to the second battery (usbs/cig sockets/anderson plugs) with the only draw on the main battery other than ineos stuff, being a uhf radio and an led camp light on a roof socket. I would like to move the 3 roof sockets over to the second battery but haven't yet.
It feels to me that the car's system does not like the batteries to be fully charged with 85% being the goldilocks number. Anecdotally I feel If you drop into the 70s it will crank up the charge current but after 85% it fights you on full charging by bleeding off charge somehow and only very slowly charging. But you can get 100% through long driving or constant solar input.
At this stage I have no reason or desire to change the system. I can see what it is doing and it appears to be working... for me.
You will see the answer to this in the Smart Alternator documentation posted some months ago. I’ll attach a link below.
To paraphrase, and by our observation, the system stabilises guided by actual use. We do a lot of driving, and have a fridge running pretty much constantly, so ours maxes out at 88-89%. According to the documentation, this will decrease as the battery life advances.
Periodically, the BMS will run the battery all the way up to 100%. Ours has done that three times in our year of ownership which leads me to think that this is an isochronal not a conditional function. Unforunately I haven’t been precise on recording the date/engine hours of this event so I’m hypothesising. If it’s in the document I missed it!
The system runs at the ceiling mentioned (80% of max, see p.6) for reasons of emissions reduction (so that a percentage of power consumed by the system is generated by energy recuperation rather than burning fuel): a saving of up to 3%.
Apologies if you’ve read the below post from @NQ94 this already, but if not it’s a rather interesting system and worth a look in my view.
Post in thread 'battery charge limitation'
https://www.theineosforum.com/threads/battery-charge-limitation.12415425/post-1333276455
Well that is some interesting reading. While im in general a big fan of optimizing efficiencies, some of the logic is lost on me, like the vehicle knowing better than me when i plan to be stopping for a night or more and needing an increased SOC. This does explain the atypical ineos system a bit better, though Im not convinced the Cteks would not do a better job given the opportunity, and im not keen finding my primary down to 45% after a few days sitting. Im going to follow along the BM200 graphs a bit longer, then i will probably try the typical ctek arrangement as described by ctek. The last couple days had been sun/cloud and with just an 80w solar panel to the d250se the aux has been sitting above 13v and 100% SOC, though it doesnt seem to be trickling back to the starter as described by ctek. Today is suppose to be nice and sunny so hoping to see something of that sort today. I like the idea of the simarine quadshunt described above, i might try that if my wiring adventures get much more involved
I'll be posting in Classified but I am selling my brand new never been used CTEK 250SE. I originally bought it for the Station Wagon but switched to the QM with out the dual battery system. I bought a 200ah battery that states optimal charging to be between 40 to 90 amps. The blend between CTEK 120 and 250 would put out to much Amps. Looking at 350 plus shipping.
Two questions that remain unanswered for me:
1) Will start assist still being available when i swap the original Aux Battery for a Lifepo4?
2) Why is the "fridge" connector on the 120s not usable?
I would think that you can use the LiFePO4 battery to jump start the vehicle if the primary battery is flat, but you can't combine a LiFePO4 battery with an EFB as a dual battery system because of the different voltages. LiFePO4 is fully charged at 13.3 - 13.5 Volts. EFB is fully charged at 12.7 Volts. Combining the two will draw the LiFePO4 battery down to the level of the EFB and not long after the LiFePO4 battery reaches 12.7 Volts, the LiFePO4 BMS will shut down the battery.
So it is very likely that the function of the Smartpass 120s to connect the second battery while starting is disabled with a Lifepo4 type household battery. So you loose this safety net when you install a Lifepo4. Would you agree?
1) as noted by @Znarfgh the smartpass isn't designed to charge a Li battery. Also most Li batteries can't handle the current draw required to start a vehicle.
2) the reason is the consumer post draws directly from the Auxiliary battery. In the INEOS implementation all loads are wired to the starter battery and the Auxiliary battery is purely used for emergency starting. If you made connections to the consumer post you could also flatten the Auxiliary battery. Section 8.1 in my manual explains further.
Steve
Steve
Did INEOS actually give that answer to Question 2? Because the earlier responses in this thread (which I was just reading) was never that clear -they were gobbledygook responses. Or did you work it out?
I have always avoided the 120S outlet. My accessories are wired direct to the aux battery terminals.
Did INEOS actually give that answer to Question 2? Because the earlier responses in this thread (which I was just reading) was never that clear. I have always avoided the 120S outlet. My accessories are wired direct to the aux battery terminals.
No but if you read the Ctek documentation closely, the consumer post draws from the Auxiliary battery when the car is switched off. So using that to power your appliances could flatten the Aux battery.
In summary, the INEOS Help Desk never read the CTEK Manuals before they answered with gobbledygook.
I think there is also a CTEK Service Bulletin somewhere warning people about overloading the consumer post.
Ok maybe i got this wrong. I thought the "fridge" consumer outlet switches of automatically before the aux battery is drained. Isn't it?
Ok now I am confused because in post #1 of this thread states the following
"The CTEK SMARTPASS 120S is the Lithium version (plus other chemistries) installed on the INEOS. The CTEK SMARTPASS 120 (no S) is the non-lithium version. Add S for Lithium"
Here my conversation (June 2023) with CTEK service on the question whether the 120S ist _really_ suitable to connect an EFB starter batt to a LiFePo4 consumer batt. In the end, they recommend to kick out the 120S and install 2 x 250 instead. Which makes sense to me technically, and would end up with a traditional setup:
[CTEK] Hello Johen,
I have done some measurements on vehicles with EFB batteries.
Charging voltage peaks at 14.8v when coasting down and breaking aprox. max 1 minute and stabilized at 14.2v. When accelerating the voltage decrease to 13.2v
Tested several brands and it seems to be similar charging strategy. Not an issue for LiFePo4 BMS with that limited voltage peaks at all. This has also been tested on several leading LiFePo4 batteries. New models and old models 5-6 years.
Med vänliga hälsningar/Best Regards,
Mikael Magnusson
[TD5-90]
Hello Mikael,
thank you for your quick reply.
My intended Li-battery is Liontron, they state an absolute max. voltage of 14.6V, otherwise the BMS will turn off.
A general problem with the Smartpass 120S will, IMHO, be the fact that the charging current is not limited. The alternator in my vehicle actually puts out a lot more than 200A (measured, with the EFB battery discharged to 12.0V), and later goes over 14.6V. I understand that the D250SE controls & boosts charging current to the aux battery as long as the voltage of the starter battery is lower than the 14.2V of the LiFePo4. But how will current limiting be possible once the Smartpass120S turns on & bridges the D250SE?
If the alternator puts out 14.6V or more, the conditions for turning on the Smartpass120S are fulfilled, and the D250SE is not operational. In this case, current controlled charging of the LiFePo4 aux battery is not possible, to my understanding.
Thank you very much for clarification!
Kind regards,
Jochen
[CTEK] Hello Johen,
We have not tested your battery brand in our battery lab., but i assume there are the the same strategies for BMS also for your battery? The BMS does not cut of the charging immediately if the threshold of 14.6volt is exceeded. It is a function of cell temperature, state of charge etc desires the cut of time.
Your alternator seems to deliver constantly to high voltage so it will be better if
you install 2xD250SE. Usually the alternator voltage decrease after some minutes in operation and usually if it is loaded with high current.
Mikael Magnusson
