Torque settings - various
When angle torque values are found a note "Renew bolt" should be added because these are tightened over the yield strength. Re-use will break or at least stretch the bolt and correct force on the joint will not be achieved.
images
I have decades used following general torque values for 8.8 bolts and 8 nuts if nothing else is available. Take care when use these.
  • M5 - 6 Nm (5-7 Nm)
  • M6 - 9 Nm (7-10 Nm)
  • M8 - 25 Nm (22-28 Nm)
  • M10 - 45 Nm (40-50 Nm)
  • M12 - 90 Nm (80-100 Nm)
  • M14 - 105 Nm (90-120 Nm)
  • M16 - 180 Nm (160-200 Nm)
  • UNC 1/4" - 9 Nm (6,8-9,5 Nm)
  • UNF 1/4" - 9 Nm (8,1-12 Nm)
  • UNC/UNF 5/16" - 24 Nm (20-27 Nm)
  • UNC/UNF 3/8" - 39 Nm (35-43 Nm)
  • UNC/UNF 7/16" - 78 Nm (68-88 Nm)
  • UNC/UNF 1/2" - 90 Nm (81-102 Nm)
  • UNC/UNF 5/8" - 136 Nm (122-149 Nm)
Does anyone know the Torque settings for the three threaded studs that bolt to the spare wheel mount on the rear door?
The mount itself to the rear door is 79Nm, the Spare tyre nuts are 70Nm and Locking Box to Mounting ring is 24Nm.
Thanks!
Big update to the Main Torque Table, from here. now sorted in alphabetical order based on first column.
TORX & TORQUE TABLE
Head Type
Torque Setting
Comment
Airbox screws
PZ3 (Pozidriv 3)
Thanks to @Tinki and @Michael H
Anchor points in cargo area
Torx T45
Not sure where these came from as they were surplus, from the rear drawer install.
Battery compartment cover bolt (5 seater only)
Torx T50
Thanks to @bakepl here.
Bolts along each side of the bonnet/hood adjacent to seals
Torx T30
Bolts attaching the cargo barrier to the battery box (2 seater)
Torx T50
2-seater model only. The bolts that attach the 2-seater cargo barrier to the battery box.
Bolts on the bonnet/hood U bolts
Torx T30
Bolts used in forward roof mounts, under the shrouds
Female hex, use 4mm Allen Key*
Look here.
Bolts used on prop shaft/tail shaft
Torx T45
Thanks to @Tassieman here.
Bolts used on the front raised tie down points near the cargo barrier
Torx T40
2-seater model only. The tie down points on top of the battery box close to the cargo barrier. All 4 of my bolts needed to be tightened (2 each side).
Bolts used to secure L track in cargo area
Torx T50
Six bolts are used to secure L Track rails on the cargo area floor.
Bracket bolt on grab handle
Torx Plus T25P
Busbar studs
M6
M8
M10
9.8Nm
4Nm
16Nm
M6 range – 8.4 Nm to 11.2 Nm
M8 range – 12 Nm to 16 Nm
M10 range – 14 Nm to 18 Nm
Both the 5 stud and 7 stud versions have a mixture of stud sizes, depending on the circuit rating. The higher the circuit rating the bigger the stud. You must work out the stud size and torque accordingly. The busbars can vary between models, so you need to look at each stud size before you torque them down.
More information here.
CTECK 120S & 250SE – terminal screws
Female hex, use 5mm Allen Key
8 Nm/71 Ib
CTECK 120S & 250SE, base mounting bolts
M4 or ST4.2 screws/bolts
2 Nm/18 lb
Diff cover bolts (front)
M12 x 1.5 x 30 (2 bolts)
M10 x 25 (2 bolts)
77Nm
44Nm
More information here and here (Installation Guide).
Diff cover bolts (rear)
M10 x 25 (4 bolts)
44Nm
Door hinge bolt (exterior)
Torx T50
Front and rear diff plugs
31Nm
Headlight surround
Torx T27
INEOS Picnic Table bolts
Torx T25
Torx T27 are used on the plastic trim behind the picnic table.
Larger anchor bolts used in rear roof slot
Torx T40
Bolts were removed as part of the rear roof shelf install. Look here.
License plate light shroud screws
Torx 20
These lights illuminate the rear number plate. Thanks @parb
Lower door sill bolts
Torx ?? or
Male Hex M10#
The bolt type (Hex head verse Torx) can vary between cars.
Oil filter cap
32mm male hex#
25Nm
More information in this thread.
Oil sump plug
M12 Hex x 1.5
25Nm
Plastic trim bolts on both rear doors
Torx T27
All my bolts needed some tightening, but I did not overtighten them. However, on the INEOS Picnic Table they used Torx T25 bolt heads, not T27 – go figure!
Roof Rack/Bars
Mostly female hex*
Various
The INEOS Fitting Guides for Accessories often have the various bolt types and torque settings. The head type is commonly a female hex,* on a M6 or M8 bolt.
Screws securing rear door ladder
Torx T40
15Nm
Suggested torque setting from LeTech on their rear ladder replacement.
Smaller anchor bolts used in rear roof No 2
Torx T25
Bolts removed as part of the rear roof shelf install. Look here.
Steering and Suspesnion - Front
Various
Various
See Rok Dr Guide Paragraph 9.6 here.
Suspension rear
Various
Various
Transfer case plug
Hex socket 12mm
15Nm
Rok Dr Guide says 8mm socket. Clarify.
Under door trim
Torx T30 and M10 hex socket
Utility Belt bolts
Torx T30
But it seems a T27 may work in an emergency. It did for me.
*Commonly loosen/tighten with an Allen key or hex bit. #Commonly loosen/tighten with a socket, spanner or wrench.
Methodology: I take a selection of Torx and Torx Plus bits and work out which fits the best. When there is uncertainty, I look closely at the shape of the screw/bolt head.
General torque values (not INEOS specific) here.
