Has anyone added a towing hitch after?
CloudVisual
8:28 PM
Harwoods, Portsmouth. They were very helpful.
Interestingly, I had mine in for a warranty issue fix and they said the module for towing was installed and couldn't see why the OEM towing electrics couldn't be installed. When changing the module it caused the TSA to disable, which surely shouldn't exist on a model which hasn't had to programmed at the factory (I'm guessing here).
Either way, I may give them a call. Do you happen to know if this work was done solely by them or did they call in Buzz Overland to do the work?
Eric
8:28 PM
Scotland
I was told it's approx £4000 from my dealer, is that about right, seems a bit steep??
Very, I'm sure if spec'ed at build it was a circa £650 option
Back in Black
GG-6681
3:28 PM
South Dartmouth, MA, USA
I asked my dealer here and they said the factory hitch would be about $3000 to install. They also quoted their own aftermarket hitch install @ $884 as a better option. I decided to order a new hitch from CAtuned - cost me $305, including shipping - which should be here Friday. I'll have to deal with the wiring harness later. So it seems like the factory option is ridiculous, by a lot, after the fact!
anand
3:28 PM
Maryland
Just remember that CATuned's hitch isn't rated for towing...
edit: Also the bulk of the "OEM" implementation after the fact is the cost of the TRM (the towing module that interfaces with all the other electronics on the vehicle) and the wiring
Back in Black
GG-6681
3:28 PM
What makes you say that? The website states it's for towing. It doesn't look any different from other hitches I've had in the past. I don't really do much so I'm certainly no expert. I only need the capability to tow a light duty trailer (dump runs, etc.) and it appears to be adequate for that application. Is there something I'm missing?
Oscar3rd
2:28 PM
Texas, USA
I can accommodate you with hitch and bolts. 375.00 plus freight and tax
anand
3:28 PM
Maryland
Their disclaimer states:
"CAtuned Off-Road assumes no liability for damages, accidents, or any other incidents that may result from using this hitch receiver for towing purposes. Please be aware that load and pull testing have not been conducted on this product."
The only hitch that has actually been certified (to my knowledge) for towing is the OEM unit, which is not too dissimilar in price
Oscar3rd
2:28 PM
Texas, USA
Thanks. I can see where this hitch appears to be more robust. What is the thickness of the steel?
It is comprised of 1/2 mounting plate, with 1/4 gussets. Our hitches are magnafluxed and x-rayed for defects prior to paint. Insured.
Oscar3rd
2:28 PM
Texas, USA
It is comprised of 1/2 mounting plate, with 1/4 gussets. Our hitches are magnafluxed and x-rayed for defects prior to paint. Insured..
Mossy INEOS in Houston, Texas is keeping a couple on the shelf, they are out at the moment, I will be dropping a couple more of them off this week or you can order directly from me.
361-319-5434 phone or text
Marty Israel
Thanks!
Back in Black
GG-6681
3:28 PM
Marty Israel
Thanks!
Thanks Oscar3rd. I'll have to give it some thought.
Back in Black
GG-6681
3:28 PM
Thanks anand. I will ponder on this.
Oscar3rd
2:28 PM
Texas, USA
Fyi … ours have been tested for the towing capacity of the INEOS Grenadier and then some😁. I have 3 of the Grenadiers ( addiction) have 2 of the hitches installed on my own vehicles…they are built exceeding the original equipment specs. Any questions give me a ring. We supply the bolts as well because everyone has had a hard time sourcing them being they are fine thread.
361-319-5434
Marty Israel
Back in Black
GG-6681
3:28 PM
361-319-5434
Marty Israel
Thanks Marty.
Tom D
8:28 PM
Berwickshire
I found out today that Stirling Trailer Centre are doing them. Its a Witter bar and (presumably) an INEOS loom.
Bradysdad
2:28 PM
Wisconsin, USA
I don’t have trailer stability control or any of that, but I was able to wire up all the lights to work correctly and I don’t get error codes. I used a Bronco trailer wiring harness. My point is, it can be done without running it through the Grenadier system.
Thank you for the update. Are you using a trailer brake controller as well? Please provide any details you can. Thanks!
Bradysdad
2:28 PM
Wisconsin, USA
I have the hitch receiver for sale . They are 375.00
Aftermarket receiver with bolts. 375.00
i have aftermarket receiver 375.00, includes bolts.
I just installed one of Oscar's receivers and they are very well made and easy to install (10 min). Oscar is also very responsive to messages. Would definitely do business with him again!
