Harwoods, Portsmouth. They were very helpful.Which dealer was this out of interest? So far I'm getting a firm no from the ones I speak to.
Interestingly, I had mine in for a warranty issue fix and they said the module for towing was installed and couldn't see why the OEM towing electrics couldn't be installed. When changing the module it caused the TSA to disable, which surely shouldn't exist on a model which hasn't had to programmed at the factory (I'm guessing here).Harwoods, Portsmouth. They were very helpful.
I was told it's approx £4000 from my dealer, is that about right, seems a bit steep??Harwoods, Portsmouth. They were very helpful.
Very, I'm sure if spec'ed at build it was a circa £650 optionI was told it's approx £4000 from my dealer, is that about right, seems a bit steep??
I asked my dealer here and they said the factory hitch would be about $3000 to install. They also quoted their own aftermarket hitch install @ $884 as a better option. I decided to order a new hitch from CAtuned - cost me $305, including shipping - which should be here Friday. I'll have to deal with the wiring harness later. So it seems like the factory option is ridiculous, by a lot, after the fact!I was told it's approx £4000 from my dealer, is that about right, seems a bit steep??
Just remember that CATuned's hitch isn't rated for towing...I asked my dealer here and they said the factory hitch would be about $3000 to install. They also quoted their own aftermarket hitch install @ $884 as a better option. I decided to order a new hitch from CAtuned - cost me $305, including shipping - which should be here Friday. I'll have to deal with the wiring harness later. So it seems like the factory option is ridiculous, by a lot, after the fact!
What makes you say that? The website states it's for towing. It doesn't look any different from other hitches I've had in the past. I don't really do much so I'm certainly no expert. I only need the capability to tow a light duty trailer (dump runs, etc.) and it appears to be adequate for that application. Is there something I'm missing?Just remember that CATuned's hitch isn't rated for towing...
edit: Also the bulk of the "OEM" implementation after the fact is the cost of the TRM (the towing module that interfaces with all the other electronics on the vehicle) and the wiring
I can accommodate you with hitch and bolts. 375.00 plus freight and taxWhat makes you say that? The website states it's for towing. It doesn't look any different from other hitches I've had in the past. I don't really do much so I'm certainly no expert. I only need the capability to tow a light duty trailer (dump runs, etc.) and it appears to be adequate for that application. Is there something I'm missing?
Thanks. I can see where this hitch appears to be more robust. What is the thickness of the steel?I can accommodate you with hitch and bolts. 375.00 plus freight and tax
Their disclaimer states:What makes you say that? The website states it's for towing. It doesn't look any different from other hitches I've had in the past. I don't really do much so I'm certainly no expert. I only need the capability to tow a light duty trailer (dump runs, etc.) and it appears to be adequate for that application. Is there something I'm missing?
It is comprised of 1/2 mounting plate, with 1/4 gussets. Our hitches are magnafluxed and x-rayed for defects prior to paint. Insured.Thanks. I can see where this hitch appears to be more robust. What is the thickness of the steel?
Mossy INEOS in Houston, Texas is keeping a couple on the shelf, they are out at the moment, I will be dropping a couple more of them off this week or you can order directly from me.It is comprised of 1/2 mounting plate, with 1/4 gussets. Our hitches are magnafluxed and x-rayed for defects prior to paint. Insured..
Thanks Oscar3rd. I'll have to give it some thought.Mossy INEOS in Houston, Texas is keeping a couple on the shelf, they are out at the moment, I will be dropping a couple more of them off this week or you can order directly from me.
361-319-5434 phone or text
Marty Israel
Thanks!
Thanks anand. I will ponder on this.Their disclaimer states:
"CAtuned Off-Road assumes no liability for damages, accidents, or any other incidents that may result from using this hitch receiver for towing purposes. Please be aware that load and pull testing have not been conducted on this product."
The only hitch that has actually been certified (to my knowledge) for towing is the OEM unit, which is not too dissimilar in price
Fyi … ours have been tested for the towing capacity of the INEOS Grenadier and then some. I have 3 of the Grenadiers ( addiction) have 2 of the hitches installed on my own vehicles…they are built exceeding the original equipment specs. Any questions give me a ring. We supply the bolts as well because everyone has had a hard time sourcing them being they are fine thread.Thanks Oscar3rd. I'll have to give it some thought.
Thanks Marty.Fyi … ours have been tested for the towing capacity of the INEOS Grenadier and then some. I have 3 of the Grenadiers ( addiction) have 2 of the hitches installed on my own vehicles…they are built exceeding the original equipment specs. Any questions give me a ring. We supply the bolts as well because everyone has had a hard time sourcing them being they are fine thread.
361-319-5434
Marty Israel
