GrenX Ineos Grenadier 68L Auxiliary Fuel Sub Tank Brown Davis
Hi Denis. Great job. I have just ordered the BD tank and fitting. I thought of fitting myself but thought the exhaust had to be welded in situ to complete the job. I could only find the LRA tank instructions and indicate fully welded. Fitting charge was quoted at $870. Will be great to see some progress pics and finished job. I will instruct them to use a supplied Deutsch DTP plug on the driver side footwell instead of the power source as described in the BD instructions. Just got to split the power source as already run extra USB chargers from DS footwell.
Good Luck
Terry
Hi Terry
The BD "welding" is just a recommendation for a couple of tack welds to hold the extension in place...there is really no need to weld the exhaust if the supplied clamp is set close to the edge and firmly secured. I'm also hesitant about welding in close quarters plus need to make sure vehicle is really "asleep" prior to disconnecting battery cables so that the vehicle is fully isolated
My last hurdle is "fighting the beast " to re-install the composite wheel well cover. Damned if I can wriggle/rearrange the replacement filler tube sufficiently to allow the cover into place. The T -Junction is as close to the bend in the main tank L hose inlet as possible (after it was trimmed) and the filler tube is the later model with the shortened 35mm section post final bend.... what else is there🤔
I note elsewhere one of our hardy DIY team has resorted to reshaping the wheel well cover with a hot air gun to accommodate filler tube bulge. I'm contemplating that at the moment 🤬. 20250130_140244.jpg
So near yet so far!!
The fitting fee quoted is probably very reasonable. A hoist would be a luxury 😆.
I guess there's a few reasons I chose the DIY route mentioned elsewhere... problem solving, crawling around the floor under a vehicle, beats boredom when one is closer to 80 than 70!!😂😂
I just finished installing it... What a ride. This is by no means plug and play. BMW specialists had a very hard time with this so called kit. "Pure junk", "low cost", "piece of s#it" etc... I am used to Australian standards, so I was not surprised. Bolts are unusable, washers are a joke, instructions are awful, wiring is off the shelf. But this is common to all Australian accessories, I am yet to find a vendor who understands bolt grades, washer physics and automotive grade FLRY wires. Also, it seems there is zero awareness of the notion of iterations in product design.
Friendly advice: DO NOT CUT the exhaust where the manual says. Instead, measure ten times and cut once. My exhaust was cut according to the manual, and it ended 3cm short of where is whould be in order to have enough clearance from the stabilizer bar. Nope, they did NOT test the fitment at full flex, and now I have a big dent in their crap pipe extension.
I have yet to fit the wheel plastic arch. It seems it will need extensive and creative ways of deforming and moulding.
@alexandruast I feel your pain! I changed out several bolts for higher grade versions.
I've spent hours trying to position the filler pipe to accommodate the liner... they just won't fit together without the wheel arch liner being re-moulded to change its contour!!
GrenX advertising on YouTube doesn't indicate whether they have actual experience of fitting the Brown Davis tank (which they sell under their brand).. and resolved the issue with the wheel arch liner.
I've contacted Brown Davis re. the problems with the wheel arch liner... I'll report back.
DenisM.
DenisM.
Hi Denis,
Feel your pain. I will supply the power for the installers for my setup through the front DS aux power. i already have a Deutsch plug so i will double off that to give waterproof connections. As for bolts and fixings it appears that cheapest is best. Look forward to the BD reply
Terry
Another issue, the vapor lines coming together in the T piece supplied. The plastic pipe going into the main fuel tank, which requires cutting and fitting into the tee, is consistently larger in diameter than the tee, the supplied clamp wont seal and there will be leaks if you fill the tanks to the brim. Brown Davis strikes again...
One more thing. After fitting everything and filling up the tanks, because of the overhang weight, the distance to bump stops is 3cm, before adding anything else in the car. No people, no gear, no tent, on level ground. A lift kit is not only recommended. A lift kit or GVM upgrade IS ABSOLUTELY NECESSARY.
The vapour line T piece seems to be a GrenX mod. The BD kit has a HDPE/nylon(?) ribbed t-piece which seals very well with no hint of leaking... (I've sent you a DM offline);)
I assume you have the red triangle rear springs?
It's the original one supplied by BD.
El-0000021752, blue triangle. EI-0000021753 is the only one above that (black triangle), but I don't think it's sufficient. I've ordered the Eibach Pro Lift Kit +3cm
BTW, did anyone tried to keep the original fill adapter and not install the supplied one? Upon further inspection, the quality of the BD hi-flow adapter, compared to the original Ineos one, is night and day. I am thinking of reverting the install for the fill adapter, but have no idea if it fits, mods or not.
I had a few people asking me what's the thing with the 12mm metal tee, because it should be nylon.
This is the content of my kit, you can clearly see the metal tee.
Hi Alexandruast,
Sorry that you have had problems getting your GrenX, Brown Davis auxiliary fuel tank installed.
In my experiance more than 50% of mechanics are competent, but some mechanics, especially mechanics working in car yards are really only service mechanics, and have little to no natural mechanical aptitude.
The Brown Davis tank is good quality I put one of the early ones in myself up my driveway, you can see my feedback on Topcat's Brown Davis auxiliary tank thread.
If A mechanic cut my exhaust without doing a conservative cut first I would be looking for another mechanic, and incidentally all the supplied bolts in my kit were 8.8 and 10.9 rated bolts, and galvanised.
Australia makes some excellent quality products, especially in the 4x4 aftermarket segment, and we have quite a harsh environment in Australia for testing those products.
Maybe you should direct your anger to the installer,
Steve.
That is not the case. The instruction manual clearly states where to cut. If my mechanic cuts somewhere not according to the manual, I would be looking for another mechanic. I don't know how stuff is done in other parts of the world, but at least in Europe we trust instruction manuals and rigorously follow them.
Supplied bolts were crap, at least according to my local area standards. Usable on gardening and furniture projects, not on automotive.
Nope, because he did nothing wrong. Nothing in the world can change that:
1. The installation manual is awful.
2. The wheel liner cannot be installed afterwards because the supplied filler neck is of the wrong dimensions.
3. The filler neck quality is night and day vs the ineos original one.
4. The provided metal tee leaks. BD replaced the nylon one with a shitty metal one without testing.
5. Wires are off the shelf (this is unacceptable for automotive engineering, the only accepted wires are FLRY or other automotive grade equivalent, not generic wires).
I think you'd like to use txl or sxl wire, it sounds crazy if they used generic parts store wire like THHN.
I also think you want to use connectors over solder for joints to ensure vibration tolerance in this location. Great insulation, chemical, mechanical and temperature properties are key for the wire you want to use for this location.
I suspect that the wiring standards I quoted are more used in north America, I'm sure there are corresponding iso/iec standards. I did a quick look and at least a couple of German companies makes wiring to the this specification.
If I recall correctly flry wire is mostly used in motorcycle applications. It probably works too.
They should have, but I doubt anyone cares. I had a lengthy discussion with an ARB representative in this regard a few years back, all their wiring for compressors, lights, everything, is unmarked off the shelf. Same for bolts, at least for the products I received. Got unmarked mounting bolts for BP-51 bypass shocks, imagine that. Made in China, most likely, for lowering cost. Never had issues like this with an EU or American company.
Hi Denis, I have decided to fit the tank myself. Have you had any help from BD or success in completing the fitting. Any guidance appreciated! Mine should arrive next week. Apparently Perth BD warehouse had the tanks in stock but had to wait for exhausts to be made up. Might be a revised edition?
Terry
