Fuel tank auxiliary
I love the idea of a bigger fuel tank, having come from a 120 series prado with 180 litres.
I did just watch a YouTube video of a group doing the canning stock route (where you need the big fuel capacity) . Their BD replacement/additional tank (under a troopy, the replacement tank was 180 litres by itself) began to leak then had a major crack, needed to be drained and was no longer usable.
Probably because of the size of it, and rough conditions, but I don't know. Food for thought if I was planning a trip like that. The plastic tanks on the side and roof have redundancy advantages.
Having said that, the track was also very overgrown. You could cop a stick through a tank on the side just as easily.
The BD tank sits above the Ineos Grenadier rear bash plate, so it is well protected and very well made, it is reinforced where it needs to be reinforced, and the welds are excellent.
I have had a few BD tanks in the past, SWB Land Cruiser, SWB Nissan Patrol, Land Rover Discovery 2 TD5 manual, and I always fit them my self, this BD Ineos Grenadier tank is superior.
I have done 1,400km on dirt so far with the BD tank fitted and am leaving tomorrow for a week in the Flinders Ranges, the Flinders has some good tracks.
One note is if you transfer fuel from the BD tank to the main tank while driving it confuses the Ineos fuel gauge, but if you fill the tank with the vehicle switched off it is the same as filling from the service station so the fuel gauge works fine.
I just finished installing the Brown Davis tank to my diesel Grenadier a couple of days ago up my driveway, so outside in the middle of winter it took me more than the 6 hours that Brown Davis quote, in fact more like 12 hours.
I don't think I work as fast as I used to, but if I did another one I think it would be 2 to 3 hours quicker, so probably 9 or 10 hours.
There are a couple of things left off the instructions that may help others, one is you have to cut the captive nuts off the rear bash plate support legs and repaint them so that you can attach the support brackets for the new tank.
The instructions don't give you the length to cut off the factory tank entry 38mm filler hose to install the new truck stop friendly filler neck and T junction, the answer is 40 - 45mm so to get to that length I did a 15mm cut, then an attempted fit, then another 15mm and a attempted fit, then 10 mm, and it then fitted, that will save you a bit of time.
The supplied loom wasn't long enough, but I used A firewall grommet as the entry point, ( the instructions want you to go through the floor ) but adding some extra wire is an easy fix.
For the power supply for the fuel pump and fuel gauge I used the front right footwell auxiliary power outlet ( very easy ) as there was no way I was going to use the supplied interruption clamp in to an ignition wire as suggested in the instructions.
I like the idea of being able to transfer fuel in to the main tank while at camp, and without the ignition on.
But overall the tank is very well made, and fits perfectly, and no special tools are required.
If you have access to a hoist the fitting time may be closer to the quoted 6 hours.
The 2 supplied "hose fuel emission 38mm X 60mm length" would be far easier to fit if they were 100 to 120mm in length.
Overall I am happy with the quality of the Brown Davis tank.
I used a V6 ( Buick motor for Americans ) VN Commodore steel fuel filter as they are the biggest inline fuel filters you can get, instead of the small in comparison Brown Davis supplied plastic fuel filter.
Brown Davis must be continually improving.We did not cut off any nuts nor the factory entry filler hose,the loom was long enough when run inside the body picked up ign jumper fuse from fuse box.Agreed had to obtain from local outboard shop a length of 38/40mm fuel filler hose to ease fitment of the supplied aux tank filler pipe,also removed /replaced the obstructive brake hose bracket.Only used the supplied P clamp to secure the larger replacement filler but made up a bracket to secure the ad blue filler to the original mounts.The system works well,if pump is left on ,it will merely circulate between the tanks ,not overflow.no problem using hi flow nozzleGood idea using metal filter Ryco S4413.All in all a straight forward install,the hoist made it easier.Driveway job would have us suffering for days after.
No doubt Brown Davis and LRA will eventually produce a similar tank for petrol models able to utilise the Ad blue tank area.
Yep from all reports they are very good. I'll probably end up doing it too, seems a very good option especially if towing a van, which is in our future plans. I'd say (in that particular case) it was more the size of that tank, and prevailing conditions .
Brown Davis must be continually improving.We did not cut off any nuts nor the factory entry filler hose,the loom was long enough when run inside the body picked up ign jumper fuse from fuse box.Agreed had to obtain from local outboard shop a length of 38/40mm fuel filler hose to ease fitment of the supplied aux tank filler pipe,also removed /replaced the obstructive brake hose bracket.Only used the supplied P clamp to secure the larger replacement filler but made up a bracket to secure the ad blue filler to the original mounts.The system works well,if pump is left on ,it will merely circulate between the tanks ,not overflow.no problem using hi flow nozzle.All in all a straight forward install,the hoist made it easier.Driveway job would have us suffering for days after.
That is interesting, they must be constantly improving as you said, I also made a similar bracket with some scrap steel but used it to secure the hi flow filler pipe, I used the original mounting spot for the ad blue if I remember correctly, but that was one of the last jobs after a long day so I may be confused.
Yes I was a bit sore, a hoist would have been nice.
I posted elswhere that I collected the 68L aux. diesel tank from the BDA warehouse north of Brisbane last Friday. When I commented that I'd noted the experiences of early buyers regarding the need for longer hoses etc, Ben, the helpful warehouse manager (owns a well customised Fieldmaster!) said that Brown Davis had taken note of early buyers' feedback and that mine had the second lot of updated changes re. hose lengths etc.
I asked about the Quartermaster, and he said that BDA has just announced( released?) a 136L auxiliary tank for it! That will be great news for those planning on extended trips
Did you look at getting it installed by someone, or did you only consider DIY?
I was told by a little birdie today, INEOS ANZ are working on a new QM show car with extended range tanks and lots of other goodies like Redarc stuff, etc. I do not know if it is BDA aux tank (my guess is it is). It is not public yet but coming over the next few months. It is something in addition to the recent Norweld build from the last week or so.
I've always tended to go DIY as the first option... I'll do the same with the tank. In deference to my creaking bones, my aircraft engineer son has volunteered to fit it and I'm allowed to "help":love: .
What are the odds that they give it to Ronny Dahl to drive the CSR?
Ronny might get a clean sheet and build his own - a cab chassis long term loaner. That is possible as the cab chassis is targeted at dual cab 70 series - just look at the build.
It is a show car, I am told. So Ronny may have to wait.
Ronny needs to get behind seany. Sean being me and if he gets his before mine, I might riot
QM Cab Chassis' have been arriving in Australia over the last couple of months. Right hand drive Diesel or Petrol models not much good for Seany. :)
Too sexy for Ronny then. Oh well, some nice eye candy for the rest of us...
INEOS ANZ would get way more mileage out of giving him a cab chassis as a long term loaner. He could do a canopy, tray, aux fuel tank, electrical fit out, lights, then a trip across Australia. They can then sell it as Ronny's OM Cab Chassis, if Ronny did not buy it.
While plans to install the BD tank have been temporarily derailed ... however, I've taken the opportunity to at least complete the wiring as far as I could. I tapped the RH footwell outlets (switch Int 2) and in doing so, added a "pigtail" so that I still have a spare connection cable behind the footwell trim. I routed the cable internally to the rear where it currently sits beside the wheelarch cover.
My question for those who have gone this way: there are two large grommets in the driver's side wheel arch, each accommodating a sizeable cable - one fore and one aft.
I presume they penetrate the wheel arch behind the wheel arch cover? (Due to space restrictions where I park at home, I am unable to remove the wheel and wheel well cover to see where to route the cable. )
So....Which of the two grommets should I use to connect the transfer pump and fuel level sender?
Thanks in anticipation...
Hi Denis,
I just went outside and looked at mine to remind myself how I did my install, I ran mine through a firewall grommet and then under the vehicle, so I can't help you on that.
I also used (switch Int 2), but for the rest of the install I may be able to help, although it did take me double the allocated time, 12 hours instead of the quoted 6 hours.
Steve.
