Yes - their version is tied to 500 combined HP electric motors - the results are pretty biblical:Maybe not what SHOULD be done though…. The thermal energy flow on that has to be epic…
I believe they also all (including base model) have center and rear lockers, 1400watt inverter, Hybrid (in the US)I could have sworn that they mentioned a disconnect for the front sway bar? I assume that means a solid axle?
I still don’t get the positioning on this. I guess you have the models you have so they brought this here because we were all Wailing about the LC leaving. The LExus GX version would have madd more sense, I think, but I guess they didn’t want to rebrand it again.
But if the base model here is $55k, a stripper 4Runner 2023 is $40-$45. I guess a TRD PRO is about $55k, which is where these start, but I’d think that the 4Runner is going up in price, unless they are going to decontent it a bit to keep the price lower.
Reports of them drinking oil big time, and a few turbos going bang.LC300 seems good so far. I know two owners and they have both excellent satisfaction with the LC300 so far. Both in GXL spec. Big expensive though for what it is.
And what is a TM?Same story with the 2.0 bi-turbo Ranger, no evidence of it being a grenade yet but I'd rather the V6 if towing.
If the new LC/Prado gets 3.5T towing in AU they'll sell a shipload to the grey nomads etc, especially now Jeep has dropped diesel from the Grand Cherokees. Although, GCM could ruin the party as the Hilux is only 5850 I think. GVM could also be an issue but an upgrade should be possible. I'd say they'll be $90-95k for the poverty pack, 105k for the upper spec. Add 20k for mods/access and you're 15-25k away from a TM.
TrialmasterAnd what is a TM?
A few reported injector issues with the 2L (T), but for this engine must be strung right out to get the power it is delivering. I would opt for the V6 3L anyday for towing... I have taken the 3L TD Ranger for a spin a few times now, it sure goes quick for a ute...Same story with the 2.0 bi-turbo Ranger, no evidence of it being a grenade yet but I'd rather the V6 if towing.
I wonder if Ineos would sell more chequerplate kits if the holes were predrilled in all vehicles and just filled with grommets or painted bolts?
Maybe the solution is adhesive? You might be able to mount them with PSA film.I was told the holes are drilled in the checker plate but the dealers have to drill the holes in the panels.
I suggested adhesive once before but was summarily shot down. Reason given was the strength of the paint. I doubt it'd be a problem in most cases.Maybe the solution is adhesive? You might be able to mount them with PSA film.
Yes, because I want to live long enough to drive a vehicle to 700,000 miles.The more over worked an engine is the less time it will last. Sure you can squeeze power out of a 4 cylinder, but dont expect it to do 700,000 miles like the V8 can.
Whether a given person sees them as comparable or not is going to depend on the person, but it’s really just an example of the reality that most people - the majority - who compare them will choose Toyota or other mainstream. That’s ok; it is exactly what being a niche car means.Someone early in this thread said that the IG and new LC are totally different birds. I disagree. The commonality is a consumer like me, who could afford the IG but doesn’t think it’s worth the potential risk in Year One. Also, I honestly don’t need that level of robustness (assuming it really is). I canceled my order and now am looking at the LC. Why? It’s cheap. I won’t mind if I scratch it or kitting it out to be my personal expression. I have to imagine it’ll sell exponentially more units than IG, so the aftermarket accessories will be plentiful. I ask feel a lot more comfortable relying on Toyota than Ineos. I don’t tow anything, just haul Boy Scouts around for camping, so the 4 cylinder should be fine. If not, I’ll look at the Lexus.
You are describing the general process of buying a vehicle.Someone early in this thread said that the IG and new LC are totally different birds. I disagree. The commonality is a consumer like me, who could afford the IG but doesn’t think it’s worth the potential risk in Year One. Also, I honestly don’t need that level of robustness (assuming it really is). I canceled my order and now am looking at the LC. Why? It’s cheap. I won’t mind if I scratch it or kitting it out to be my personal expression. I have to imagine it’ll sell exponentially more units than IG, so the aftermarket accessories will be plentiful. I ask feel a lot more comfortable relying on Toyota than Ineos. I don’t tow anything, just haul Boy Scouts around for camping, so the 4 cylinder should be fine. If not, I’ll look at the Lexus.
So my wife is brunette and dyes any sign of age out of it. Are you saying I should cancel my order?You may prefer blondes and i may prefer red heads.
We may discover both our partners dye their hair.
I hope you realize that the '23 4Runner has way more electronics and modules and, quite frankly, techy gadgets, than the Grenadier does...We bought a 2023 4Runner. You can definitely feel that it is really long in the tooth. Especially around the electronics side.
I feel that “for you” is the key qualifier to that statement.The Land Cruiser definitely is the main competitor against the grenadier.
