On the Toyota side, pretty much anything IFS and in the past 20 or so years that uses ADD; Nissan side I know it is how the Frontier and Titan work, I would imagine the Xterra as wellOn all modells?
One of Andrew SPW video's he lost an ABS sensor out in the Desert on the Canning Stock Route.To answer your questions specifically
- Off road mode will bypass the requirement that the door is closed to engage drive/reverse
- Exiting wading mode (or off road mode) can be done by cycling the ignition (with an off time >30 seconds)
- If you damage the wheel speed sensors, you will most likely lose the ability to engage the front/rear differential locks; for comparison, losing a wheel speed sensor in a Toyota/Nissan will cause you to lose 4WD
Yes but you need it in a Jeep Wrangler because the cabin isn't insulatedIt's easy to rag on creature comforts like a heated steering wheel, but it's one of those things that don't effect the vehicle's ability to get you home. As long as it has a fuse it will not leave you stranded. I find it quite nice for extreme weather in my Jeep (and if Jeep can build this feature reliably, anyone can).
Cameras and proximity sensors as well, they don't increase your odds of getting stranded.
The Grenadier does seem to be computerized in ways that do make me nervous, for instance the car refusing to move with a door cracked open. Will a faulty or damage sensor leave the car immobile? Or perhaps the vehicle refusing to exit wade mode, hindering its ability to cool itself. The lockers also rely on wheel speed sensors; what happens if those get damaged or faulty?
Time will tell.
That’s interesting because I lost an ABS sensor in some ugly stuff at Fraser Island. The dash was lit up like a Christmas tree for a week, but I didn’t lose any functionality of the 4wd system - either CDL in high, or low range at any time. Perhaps it was different issues?One of Andrew SPW video's he lost an ABS sensor out in the Desert on the Canning Stock Route.
Was stuck in 2WD which meant lots of towing.
Had he been by himself he wouldn't have made it.
Losing a abs sensor will disable traction control, but in a car with manual diff locks it shouldn't matter at all.That’s interesting because I lost an ABS sensor in some ugly stuff at Fraser Island. The dash was lit up like a Christmas tree for a week, but I didn’t lose any functionality of the 4wd system - either CDL in high, or low range at any time. Perhaps it was different issues?
Ahhh you said the magic words here, CDL... So if your system is full time 4WD, there's nothing to "lose" per se. On the IFS trucks that are selectable 4WD, loss of wheel speed sensor disables the ADD (what engages the front diff)That’s interesting because I lost an ABS sensor in some ugly stuff at Fraser Island. The dash was lit up like a Christmas tree for a week, but I didn’t lose any functionality of the 4wd system - either CDL in high, or low range at any time. Perhaps it was different issues?
Not sure which vehicle it was in. Might have been a new landrover defender.That’s interesting because I lost an ABS sensor in some ugly stuff at Fraser Island. The dash was lit up like a Christmas tree for a week, but I didn’t lose any functionality of the 4wd system - either CDL in high, or low range at any time. Perhaps it was different issues?
Ah, I assumed it would have been a 70 series yota given his fanboi status.Not sure which vehicle it was in. Might have been a new landrover defender.
One that uses electronic traction control as main 4wd capability.
It was over a year ago
I can't find it on his website and he has a habit of taking video's down if they get negative comments.Ah, I assumed it would have been a 70 series yota given his fanboi status.
That hasn't ever been an officially tested/certified figure....The IG 14mpg was the heart breaker for me.
If my sieve of a memory serves, he knocked a wheel sensor off his 70 series on the Canning and made a point of it being able to continue with full 4wd whereas a New Defender would have been disabled. I think there was a YouTuber in the UK who then tested that and found the Defender would have been OK.Ah, I assumed it would have been a 70 series yota given his fanboi status.
Spot on. If Ineos sold every one of those in Australia, it would still be out sold by Hilux by 2 to 1. It would only be 3% of the the total market here and Australia is only about 1% of the global automobile market. Most definitely a niche.The point is to maintain the image and substance of a niche product of 20-30,000 units a year
For me the only piece of tech besides ABS/DSC, that I‘ve come to really like is the relatively new rear view camera in some vehicles. It allows you to add nets/partitions and gear into the rear load space without obstructing your view vs. a traditional mirror. If it does crap out on you, the mirror can be turned down, similar to the change in angle when someone shines their high beams in your rear view mirror, turning the mirror into a normal rear view.In one of the video's Sir Jim said he is seriously disappointed by the amount of tech they had to put in to pass global homologation standards.
I can't recall which one but I think he was driving it at the time.
So the dream and plan was to have somewhere between none and as little as possible.
unfortunately "as little as possible" means different things in different markets.
As you can see even on this forum we have people who are demanding lane departure warning, brake assist, radar cruise control, 360 camera's etc etc.
I drove one of thosePerhaps a Mercedes SUV would do
I was about to place an order for a GLE Couple when I happened upon the Grenadier.I drove one of those...a friends. A fancy, very expensive, high tech phone charger on 4 wheels
The parking lot 4-wheel steering was actually kinda cool.
Yeah, they are very similar vehicles with the same purpose and demographic.I was about to place an order for a GLE Couple when I happened upon the Grenadier.
Almost identical.Yeah, they are very similar vehicles with the same purpose and demographic.
I bet there’s a lot of folks (not auto enthusiasts) who would look at those two and say, “four doors, grey in colour, looks expensive, probably a rich asshole driving it … same shit”Almost identical.
It would be easy to mistake one for the other in a car park.
View attachment 7822702View attachment 7822703
