Grenadier Screw/Bolt head types & sizes
the steering wheel has screws near the toot button around the OK button on the right and microphone button on the left. They are very unusual M2 socket head thread cutting. The outer diameter is 2mm, total length8.25mm, with a 4.20mm diameter head. Like this, but smaller: https://www.gobilda.com/m4-thread-forming-socket-head-screws if anyone has a source for such screws, with a longer threaded portion, I'd love to know about it.
You will find m2x 10mm up to 50mm on Ebay, Aliexpress and Amazon.
These are Au sites but you should be able to find the same on US sites.
Look for m2 socket head self tapping.
The plastic number plate holder for models with the INEOS (RED) winch installed, is secured by four Torx T30 bolts. Image from @BillB It is the bolt on the right in the plastic holder next to the winch lever. Four T30 bolts in total.
img_4501-jpeg.7887814
The Exterior L track rail is secured with a Torx TX30 bolt. I previously had this as Torx T27, but did a check today.
You need to be careful with T30 and T27 bits, double check both before making a decision. I don't seem to have this issue with other Torx bits just the 27 and 30.
Does anyone know the exact specs on the headlight bezel screws? T27? Length / diameter? Pitch?
I forgot to add this option on the build sheet 🤷
And the bolts will most likely be a metric bolt size and a metric thread.
All Grenadier bolts/threads are metric. If it has a T30 head is should be an M6 bolt with a coarse (1mm) thread pitch. M6 bolt lengths reported by other members and my own investigations include 16mm 25mm and 40mm
Steve
And the
Steve
thank you so much! I can run with that info and buy a couple different sizes
How about the bolts for the center console? I lost one and would like to replace, thank you in advance.
