Fire extinguisher
drinkmorejava
12:31 AM
Virginia, USA
Under the front passenger seat. Literally just a couple of 3M velcro command strips. It's really sloppy but it works and moved the extinguisher way down the list of things to do.
12:31 AM
Massachusetts, USA
Depending on the size of the extinguisher, under the front seat is the most accessible in an area emergency. However, I fabricated a mount inside the rearmost pillar facing forward, as this is dead space and out of the way.
I was concerned about the structural rigidity of the plastic so I fabricated two aluminum backing plates and tapped M 5.0 x 0.9 thread machine screws, plus one additional self tapping screw with a collar.
Used double sided tape to hold the aluminum in place.
The plastic is held in place with several plastic fittings and I was unable to find the last one but had enough room to perform the task. Be careful if you’re prying and drilling because there is a small section of wire loom running up/down the pillar
parb
9:31 PM
Silicon Valley, CA, USA
angstorms
11:31 PM
Durango, CO, USA
I carry a E100 next to first aid kit in the front near me when I driving, and in the back I have 5lb Halotron right next to a Leatherman Raptor Rescue Emergency Sheers, with Glass break and Stap cutter.
parb
9:31 PM
I have the same Leatherman, I put it in a pouch on the driver side door. I was worried that if I'm stuck with a smashed in door that I can't reach under the seat but I can get to the door pocket to cut myself out of the seatbelt and break glass to get out. I put the fire extinguisher in front of the passenger seat for the same reason. I'm considering adding one in front of the drivers seat as extra protection
I have had to use my fire extinguisher in another car and having it universally accessible from both front seats proved really useful.
Ovrland Bill
9:31 PM
A very comprehensive setup (but that rescue tool at least looks ready to take flight in the event of a crash).
