Fire extinguisher
drinkmorejava
6:34 PM
Virginia, USA
Under the front passenger seat. Literally just a couple of 3M velcro command strips. It's really sloppy but it works and moved the extinguisher way down the list of things to do.
6:34 PM
Massachusetts, USA
Depending on the size of the extinguisher, under the front seat is the most accessible in an area emergency. However, I fabricated a mount inside the rearmost pillar facing forward, as this is dead space and out of the way.
I was concerned about the structural rigidity of the plastic so I fabricated two aluminum backing plates and tapped M 5.0 x 0.9 thread machine screws, plus one additional self tapping screw with a collar.
Used double sided tape to hold the aluminum in place.
The plastic is held in place with several plastic fittings and I was unable to find the last one but had enough room to perform the task. Be careful if you’re prying and drilling because there is a small section of wire loom running up/down the pillar
