11:24 AM
It is almost charming that you have to engage with the vehicle before rolling out. Kind of like using a choke or magneto switch in really old vehicles. It is simply part of the ownership experience.
95% of buyers don't get misty eyed over such arcane features but I get your point.
A mall crawler soccer mom tank it is not.
Max
7:24 PM
I never expected a software update that would eliminate the nanny alerts and happily bought a Grenadier anyway. It is almost charming that you have to engage with the vehicle before rolling out. Kind of like using a choke or magneto switch in really old vehicles. It is simply part of the ownership experience.
Show the bloody thing who's boss (y)
10:24 AM
Yeah. Where's the fun in that?
As the others have mentioned before, if you're stopped on a hill, and the engine is OFF, the truck WILL roll backwards before the engine starts back up. It happened to me several times early on, before hitting this button became automatic. So while this feature may be fuel-saving, it is unsafe - not generally, but in INEOS' implementation in the Grenadier.
So... This does not appear too complicated to me:
Question is......does it impact your warranty?
I have no idea by the way
Asnes
7:24 PM
Windermere, FL, USA
Mounted Owl Talon Wheels and 285/70-R17 BFG KO3. Perfect balance for stock ride height I think.
I kept the spare rim stock as I wanted continued use of the rear cubby compartment for recovery gear.
I optioned secondary Apex Quick deflate valves (the rims have 2 valves) They are awesome. You can drop 3lbs in less than 3 seconds.
7:24 PM
Colorado Front Range
I keep the spare rim stock as I wanted continued use of the rear cubby compartment for recovery gear.
Looks brilliant with the wheels matched to the roof. Really first rate. I wish more wheels had two valve holes. Otherwise to use the Apex valves you have to ditch the TMPS sensors. And I might have to copy the way you colored the Grenadier logo on the spare tire storage bin. So good.
parb
4:24 PM
Silicon Valley, CA, USA
how did you color the grenadier logo on the spare tire insert? Looks legit! Decals?
Asnes
7:24 PM
Windermere, FL, USA
Walter
7:24 PM
Toronto, ON, Canada
Now we have the same color, same grill lights, same Rosen visors and same wheels haha..
owl (Owl Outdoor)
Supporting Vendor
4:24 PM
Carlsbad, CA, USA
Ceramic coated it....first time I've ever done it to a vehicle, so far pretty impressed with the results.....
Nice 90 and the P1800 looks great as well.
Nice 90 and P1800……all white vehicle line up looks great!
DenisM
10:24 AM
"Full metal jacket".😎.. Custom Offroad 4mm SS bash plates Black Friday sale.: f/r diff, rear control arm pivots , sump/ transmission and t/f case. Was able to crawl around sufficiently to "lever" the heavier plates into place and loosely bolt in position prior to final tensioning. I'll sleep well tonight🙄
EDIT: Was most impressed that 14/20 bolt holes tapped and threaded during vehicle production, 4 bolts plus nylocs into existing brackets and remaining 2 for the t/f case plate piggybacked on to the existing (middle) attachment points for the LHS side runners.
All in all a satisfying task for an old bloke!🤣 (according to ageing neighbour!)
Clark Kent
10:24 AM
Toowoomba QLD, Australia
Noice (y)
Here @DenisM?
Dual Grenny Guy
6:24 PM
Louisiana, USA
I’m VERY impressed you were able to do it all yourself! I went the “SPP” F.M.J. route, but unlike you this ole body of mine had a difficult time trying to negotiate holding the heavy ass plates and bolting them in place, so I had to hire a shop to install for me. I tip my hat to ya sir! 🫵👏
Dual Grenny Guy
6:24 PM
Louisiana, USA
Very pretty!
Trust me it’s more than looks! 6mm thickness/heavy as hell & probably why I couldn’t install by myself. Haven’t found another under armor kit thicker. Most are around 4mm, this one is 6mm. It was only painted red to match the factory painted red frame. It will get used & probably scratched, but that’s the beauty of paint, can be reapplied. I’m not going rock crawling or taking it to the MOAB, but will be traveling across the USA looking for the best fly fishing spots off the beaten path/hidden. Well that’s the goal…..::
