I installed a fiskars axe on my molle panel. I always have an axe with me, driving up on california and oregon forest roads i've found it useful.
Wanted to fit a shovel above the axe to the right of the water tank but it just didn't fit well in that location.
I used to have a chain saw but once i got a winch i now use the axe and the winch together to get fallen trees out of trail. And it saved me some space. If the tree is massive i'll probably turn around but for smaller trees this has worked pretty well. I think i've used the axe more for firewood than for getting stuff out of the way but its like insurance, you never know when you need it...
I've got same
OUTBACK SHAKE DOWN CHANGES – ROUND 3 (2 being written up)
Today the Australian Wildlife Conservancy stickers went on the car. I found myself smiling when driving back home, as the build is now complete after some changes yesterday (those are being written up). The first time I can remember being so happy since the fatal car accident 18 months ago. The Grenadier build has been therapeutic! I am still working through some injuries and trauma but starting to feel better.
The car is back to being AWC's mobile billboard and ready for The Doc's Excellent Adventure. UK and US owners can also support AWC, as they have events on London and New York - shameless plug.
The L tracks did make fitting the stickers more challenging. Fonts had to follow AWC's guidelines, except Proudly supporting.
Observant readers will have noticed the car’s name is now official: Wally. Named after the wallaby I hit on the road earlier this year. I added a Wally sticker to the driver's side bonnet/hood. :)
In anticipation of the imminent deliveries, what did you do with your Grenadier this weekend?
Tell the community and share the love, and pictures, lots of pictures.
This thread will remain locked until the first member tells me they have taken delivery.
I take delivery of my Trialmaster on Thursday but today was a delivery day. I received three (3) oil change kits, filters, o rings and oil pan washers and a drivers side grab handle for the A-pilar from Bentley Ineos of High Point, North Carolina.
Finally, after months, I decided to do a hand wash of my Grenadier today (exterior; the interior I did some time ago).
This is always a good moment to discover some problems, like this ...
The lower part of my RAI (Raised Air Intake) is loose.
Apparently the screws (still present) are screwed in some plastic studs, and these became loose and damaged.
OK, I did quite some off road in June in Romania, and scratched the car with branches, therefore probably this is also the origin of my problem.
But anyway, "built on purpose?".
I dismounted the RAI and unscrewed the studs and did put them back at their location after some "plastic bending". Anyway, I think these plastic studs (the two white things on the next picture) will have to be replaced sooner or later.
I’ve had the same issue on my travels and ended up sticking it on with silicone sealant . That indicator that fits in the raised air intake kept falling out also.
Hi Jean,
When I disassembled my rai I put some armaflex inside to avoid vibrations.
Post in thread 'Strange vibration/rattle'
https://www.theineosforum.com/threads/strange-vibration-rattle.12415000/post-1333270612
as for the two plastic inserts, in my opinion you can replace them with threaded metal pressure inserts
did you manage to disconnect the light inside the rai?
Can you provide the part number for the drivers grab handle please?
Its not a. snorkel.
All ready for a weekend away with the van ; LHS airbag not inflating normally.
Rear spring has come off the axle perch and is jammed onto it. Tried to free it before work ; no luck. Airbag hissing a bit :(.
Not sure if it was a bad install (not by me) or I've dislocated it offroad.
Ordered a new airbag as there's no point in taking it to the installer and finding it's worse than just a split top hose.
Edit:
It's all fixed. Managed to get the installer to put it up on the hoist this afternoon.
They had to remove the shockie and spring to inspect the bag ; the hard line was kinked and split but repairable.
Lesson learned : do not put more than 5psi in the bags (Originally I was told keep 10 in...) when going offroading when there may be significant suspension flex. The bag will prevent the spring extending, and in my case it looks like it has spun around and unable to reseat itself.
So if you have a trailer, deflate when not towing and if there is likelihood of a large flex.
PS I reckon I've driven on it "injured" the past week , including some light offroad, and even maybe some heavier trail stuff last week..
Luckily no major drama!
