Warranty? Against scratches and dents?. Significantly cheaper than a wrap, and would preserve the paint warranty.
I'd bet the paint warranty is about general failure and not normal wear and tear.Warranty? Against scratches and dents?
Exactly. It won't peel off in the sun sort of thing.I'd bet the paint warranty is about general failure and not normal wear and tear.
No if there was some sort of issue with the paint, and you had wrapped it ineos won’t warranty it. Check the T&Cs in the contract.Warranty? Against scratches and dents?
The issue is it wouldn't protect the tops of the doors and front fender, great idea thoughIf someone developed “armor” to protect against trail rash that simply clipped into the belt when needed, I’d consider it
You could also attach a toilet seat like the bumper dumper on the Top Gear arctic specialYou can attach some toiletries….![]()
Or the door mounted one in the African specialYou could also attach a toilet seat like the bumper dumper on the Top Gear arctic special
Hi DaveB.I am still working on design of my detachable tables to fasten to these Utility rails
Two supports which slot into the top rail and if needed a swing down leg which slots into the lower 2 hole module. stainless steel shelf with a hinged lid panel to swing up and protect the paint from heat and splashes. If I recall correctly these rails are fastened to the frame of the door and can carry 100 kg per door
A great spot to put a hot plate or jet boil under the awning and to make lunch and a cuppa.
If you don't need the shelf you can use the supports to hold a bag for your rubbish, hang clothes/towels on to dry or if you are a lot lighter than me you could use them as another step to access the roof, depending on the shear strength of the fittings and supports.
Timing comment the TG arctic special was on UK TV last night just about at the time you made your comments. Coincidence or planning on your partYou could also attach a toilet seat like the bumper dumper on the Top Gear arctic special
In Tasmania I can't get UKTV , so it was a "coincidence" if you believe in that phenomenonTiming comment the TG arctic special was on UK TV last night just about at the time you made your comments. Coincidence or planning on your part
By the looks of it they are working on an electric version of the grenadier… electric generator in the boot and some jerrycans to allow enough range![]()
One of the questions we're always asked is "What are those holes in the side?" This explains all...🧐 | By Chandlers INEOS | Facebook
One of the questions we're always asked is "What are those holes in the side?" This explains all...🧐fb.watch
View attachment 7808402View attachment 7808404
I'm more convinced than ever that Ineos doesn't really have a clue what to do with them.![]()
Yeah, that’s peculiarly conceived. Has a bit of a “let’s post that render the work experience kid produced” feel to it.Having seen the video of the clipboard / document holder, I look forward to driving down the highway at 75 MPH with one of those dangling from a D-ring on my door, perhaps between the 4x 20L NATO Jerry cans full of petrol.
