The Utility Belt
  • Thread starter Thread starter HT
  • Start date Start date
I think they have chosen that size because it doesn't protrude past the hips of the vehicle. So you could use them on road
Once offroad you could easily stack them 2 deep on each side if needed
Seems like we will not be able to mount anything like this in the U.K. as per Grenadier manual.
“ Exterior Utility Belt (OPTIONAL) WARNING: The Exterior Utility Belt (and any items attached to it) can only be used when off-road. On-road use is prohibited. Loading equipment on the exterior of the vehicle may change the handling characteristics. Users should not load the vehicle, any options or accessories (or any part of them) beyond their intended capacities. Improper use of the vehicle or other equipment may be unsafe and could result in property damage and/or injury to users and/or other parties.”
I think there's a general abundance of caution throughout the manual; you can see why a manufacturer says it but it's not their responsibility how you use it once off the lot.
They are probably saying that to protect themselves against lawsuits when some person mounts a 20kg table on the side and hits the motorway at 160kmh
As far as I could find out yet, in Germany load attached to the sides of a vehicle must not stand out beyond the width of the car and must be properly protected against falling off. Does anyone here have any other info?
Sounds reasonable! When the cops stop me I will tell them to ask muxmax for confirmation 😀
But seriously, all I could find was §22 StVO. Nothing on the net, not even in 4x4 magazines…
If someone developed “armor” to protect against trail rash that simply clipped into the belt when needed, I’d consider it
Where would it attach to the front wings?
Be easy to have a mix - some that clipped to the utility belt and some magnetically. Significantly cheaper than a wrap, and would preserve the paint warranty.
