I noted from photos on here they were marked as EFB+ batteries - enhanced flooded batteries. They have similar characteristics to AGM but are a wet cell lead acid battery not an absorbent glass mat construction.Mine are agm
The CTEK is a smart DC/DC charger that is (in theory) designed to overcome the issues created by these new 'smart alternators'.
That is correct...hence the need ultimately for a DC-DC charger in the mix.I have just read more about this in another thread ...
It would appear that the CTEK is NOT acting as a DC/DC charger as this function is not connected ....
Diese Nummer funktioniert definitiv nicht (wie so vieles bei IA nicht funktioniert).Did you try: „Wende Dich innerhalb Europas* an die Nummer 0330 053 0885, und wir helfen Dir, wieder auf die Straße oder ins Gelände zu kommen.“
Service Fur Deinen Grenadier
Wir bauen ein Service- und Reparaturnetzwerk für Deinen Grenadier auf – in der ganzen Welt. Mehr Entdeckenineosgrenadier.com
It's better, and safer, to disconnect the starter battery first.Yes.
The Black (neg) are connected together already (common earth)
Connect, start the car, remove the lead.
It would be highly unlikely that both batteries were 'dead' - it's possible, but I would estimate that 99% of the time this would get your car going again.
"Innerhalb Europas": Welche Ländervorwahl ist da zu verwenden?Diese Nummer funktioniert definitiv nicht (wie so vieles bei IA nicht funktioniert).
The Ctek Smartpass 120s is a DC to DC charger but only a 'dumb' one. It cannot control or convert the voltage coming from the alternator. It is simply acting as a bridge to transfer charge to the auxiliary battery. You need to add a Ctek 250SE unit to the system to correctly charge the aux battery to 100% (float). The 250SE is just a smart battery charger powered by DC current instead of AC. Hence the term DC2DC charger. It can utilise alternator or solar input, but not both at the same time.I have just read more about this in another thread ...
Here's a reason why for some owners, the charge is appearing to be capped at 80%...it's to allow for additional charging under "regenerative braking".....i.e. to fill the nominal 20% reserve and not overcharge the battery...
This is well worth reading
To add the Ctek DC-DC charger in with the Ctek smartpass 120s seems like a good idea!Aux Battery Charging With Smart Alternators | 12 Volt Planet
A guide to the benefits of using battery to battery chargers to overcome split charging problems caused by smart alternators on modern Euro 5 & 6 vehicles.www.12voltplanet.co.uk
No. But if the engine warning light appears in red, I'd stop driving - otherwise you might void you warranty as such events are very likely logged permanently.Car running ok.
Engine warning light on though and cruise control stopped working.
Ideas?
YellowNo. But if the engine warning light appears in red, I'd stop driving - otherwise you might void you warranty as such events are very likely logged permanently.
No good news, I know. But worth mentioning.
I’m just learning here, used to simpler electrical, but reading about the 120s/250se devices and beginning to be less confused…. Can we simply replace the 120s with the 250se?The Ctek Smartpass 120s is a DC to DC charger but only a 'dumb' one. It cannot control or convert the voltage coming from the alternator. It is simply acting as a bridge to transfer charge to the auxiliary battery. You need to add a Ctek 250SE unit to the system to .
For me looks like errors, which come up, after low voltage. You wrote now 100% charged, see what happens after restart, and engine off.Yellow
The ”dead” battery will start sucking power from the service battery as soon as you connect them.
The current may be so high that you will not be able to start anyway, or the connecting cable may catch fire.
In general it's never a good idea to connect batteries that are not charged equally.
My 2 cents.
Have a nice day, Fabio
Yes.For me looks like errors, which come up, after low voltage. You wrote now 100% charged, see what happens after restart, and engine off.
