Yesterday my two ordered Chinese battery monitoring stuff arrived: each 18.50 euro.
Why I had to allow the "correct location" to be used by the app on my phone is still a mystery for me, only Mao knows.
<snip>
I think you may have just paid the favour back.
- some bastards on this forum made me spend more money. I bought a CTEK MXS 5.0 battery charger, arrived today: charge test with the CTEK.
Thanks Jean - I desperately try to avoid buying Chinese, virtually impossible these days. But looks like I will be spending money on these gadgets. Thanks!Yesterday my two ordered Chinese battery monitoring stuff arrived: each 18.50 euro.
I only tested the battery voltage, not the other possibilities (cranking test, charging test).
My car didn't move now for nearly two weeks for different non-technical reasons.
This is the picture of my battery status before installing the devices:
Of course, key in, ignition on.
Here some screenshots from my phone, after installing:
View attachment 7824408View attachment 7824407View attachment 7824409
I can input myself different names, but the devices are identified by different serial numbers.
The device also saves in it's internal memory the data of a longer period, 35 days according to the app manual.
When you move within the reach of your car this data is synchronized to your phone.
This is the overnight data of the main battery (similar for the auxiliary battery), I didn't open the doors of my car, not one time:
There is also a nice slider to measure voltage peaks or drops at certain moments, first image of the main battery, second of the auxiliary battery, while installing, testing, etc. and opening and closing doors. First image is from the Main Battery, second from the auxiliary battery:
Pïty that on this chart the battery name isn't mentioned!
Evaluation:
Next steps:
- Device works
- China is watching me
- battery voltage quite stable, no sensitive drop in about 24h.
- state of charge seems to be (in %) the same as what the Grenadier makes of it!
- Voltage measurement seems to correspond to the Grenadier (see the 12.1 Volt on the info screen, and the 12.13 lowest value of the main battery while installing)
I continue to play around without driving, but I am longing to finally do some travelling again early September, after delaying it three times now!
- crank test
- charging test (with the device function)
- drive test
If one in 6 people are Chinese and you have a wife and four children it would make one question whether the child eating cornflakes with chopsticks is kosher.Thanks Jean - I desperately try to avoid buying Chinese, virtually impossible these days. But looks like I will be spending money on these gadgets. Thanks!![]()
Nice toy, but 4 times more expensive than my monitors from Amazon (China?!).These battery monitors seem to just measure voltage and thus are very limited in what info it can provide. Is anyone considering a smart shunt like the Victron Energy ip65 500A that can measure voltage,%charge, amp draw and amp charging and plot all the data? This would give a true idea of what is going on with your Aux battery.
They are the same others and me are using.Yesterday my two ordered Chinese battery monitoring stuff arrived: each 18.50 euro.
Evaluation:
Next steps:
- Device works
- crank test
- drive test
OK, I agree, there are more professional solutions, and mine are toys. Doesn't measure amps indeed.These battery monitors seem to just measure voltage and thus are very limited in what info it can provide. Is anyone considering a smart shunt like the Victron Energy ip65 500A that can measure voltage,%charge, amp draw and amp charging and plot all the data? This would give a true idea of what is going on with your Aux battery.
I bought one of that model 3 years ago when my old Disco alternator was playing up; played around with it a fair bit and it always seemed to give useful info (not just "voltage"), esp if the car had been sitting for a few weeks and in winter.They are the same others and me are using.
That's what I have been telling since 1871.These battery monitors seem to just measure voltage and thus are very limited in what info it can provide. Is anyone considering a smart shunt like the Victron Energy ip65 500A that can measure voltage,%charge, amp draw and amp charging and plot all the data? This would give a true idea of what is going on with your Aux battery.
Have a look here:Is anyone considering a smart shunt like the Victron Energy ip65 500A that can measure voltage,%charge, amp draw and amp charging and plot all the data? This would give a true idea of what is going on with your Aux battery.
Or you have a very good memory or you use the search function in a very efficient manner.Have a look here:
Thread 'Victron SmartShunt 1000A install' https://www.theineosforum.com/threads/victron-smartshunt-1000a-install.12411893/
Actually neither, I had one in my hands the other day. It's a chunky monkey.Or you have a very good memory or you use the search function in a very efficient manner.
I'm not sure I'm in that camp... the detail you're providing is fantastic & I wonder if anything more is actually required or indeed once initial norms are established and understood, whether there is actually a need to see the data again, until something suggests to you that there may be an issue.
Have you looked at the Victron ones?That's what I have been telling since 1871.
But installing a high performance shunt properly is not trivial.
not everyone understands voltage, current, resistance and the relation between them.
No, it's the first time I heard of them. Victron are in general serious products, and I think they are worth a try.Have you looked at the Victron ones?
