Nice find! The engine decoder on the 12th page(8) will be fun to compare with the Ineos designations. Particularly number 7, performance classes.On the B58 document.
emax said:Aside acceleration and top speed: Is there really something which you can't do with 250 HP but with 500?
Tazzieman said:Unless you need to accelerate uphill whilst towing , the B58 torque is more than enough. The Grenadier is speed limited.If you want to go fast , buy a Porsche. You'll use heaps less fuel.
stickshifter said:1. If you read my post, you will see that I never said I wanted 500 HP. I said that if the 3.0 I6 from Stellantis can make over 500 HP and 475 lb-ft of torque, then one would think that a 3.0 de-tuned for longevity could make in the order of 350 HP and 400 lb-ft of torque. Given that the B58 is forced induction, and won't lose much power at elevation, I would be okay with 325 HP and 350 lb-ft of torque.
stickshifter said:2. My guess is that you do not live at 8,500 feet above sea level (2,580 meters), nor do you regularly drive over 11,000 foot passes (3,340 meters).
stickshifter said:Note: the Grenadier will drive better than the numbers indicate, because its power will come in at low rpms, due to the turbo. By contrast, the naturally aspirated V6 engines in this list have to be wrung out to make their full power.
Spjnr said:That's the same as the new jeep Wranglers. I guess there's some sacrifices to be made in getting these solid axle offroaders through modern safety regs. As you say though, anyone who's bothered about going more than that is in the market for the wrong vehicle!
I was reading the B57 Diesel review when you posted thisstickshifter said:Is the B58 Engine BMW’s Best Engine Ever?A glowing review of the B58:
https://www.bmwblog.com/2021/12/20/b58-best-bmw-engine/
DaveB said:I was reading the B57 Diesel review when you posted this
FlyingTexan said:Wonder how hard it would be to get the X7 series tune for the engine? The specs for the engine show the same torque curve with more power so I’m not 100% sure I buy the “we’ve tuned it for torque”. I wouldn’t be surprised if it was more of a bmw detune. The X7 does 330hp. Two things kill the longevity of an engine, temps and vibration. If the temps are good I don’t see any reason it can’t be tuned for more. I’m not looking to go 100mph but 80mph can be pretty normal on Texas highways.
stickshifter said:A lot more accessories than I was expecting! Anyone know anything about the roof rack? I suppose if you want a roof rack soon, you should order it from Ineos, since the aftermarket might take a little time (unless Ineos has been collaborating with aftermarket companies, and providing them with specs).
Spjnr said:Its a Rhino rack. Best factory fitted rack I've ever seen equipped to a new car by manufacturer. !00% being specced on mine! Being full length though it makes the safari windows a bit pointless
