- Local time
- 2:34 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
Better check underneath ~ sounds like you have a bit missing.Finally, I have zero vibration at any rpm. Just smooth all the way through.
Engel 45 = 650mm...I measured the back yesterday and I’m not at all confident I’ll get a set of 900mm drawers in the back. It’s going to be tight and they may sit slightly over the plastic edge strip right up against the doors.
Even if I do, any fridge that goes on them will need to be no longer than about 700mm to account for the seat lean, which by the way is a fixed position and can’t be adjusted forward or back.
Soooooo, anyone want to buy a 60L engel.
To be honest if they said they were bringing out a “130” vesion soon I’d cancel my order and swap. But they aren’t, so I won’t.
And I’m not sure a ute version would suit what I want.
I saw (somewhere) that only the "Ineos/Rhino" rack is approved for gutter mounting. All others negate warrant???? Surely Frontrunner will get approval?Great photos and good to hear positive comments.
Got an I Kamper set up as well although on the trailer.
Will probably be getting the Frontrunner rack for the car given the “already purchaser” Rhino wont be around till July.
Enjoy Italy, where are you going?
Paul
Hi, I can echo your observation: when you switch ignition, wait for 20-30s and only then start the motor I observed much less warnings.I’ve just got back from six hours driving today in mine - nothing exciting, sadly.
However, I too struggled to get the HVAC to work consistently to a set temperature. I noticed after a while that when you turn the temp dial, it shows the temp (in degrees) on the central screen for a few seconds. However, pressing the Auto button, didn’t hold the temperature. It just kept blowing cold air. Switch off the Auto button, and it blew hot air - without changing the temperature.
Would love to hear if anyone has mastered it.
I also had a few software issues, with a few spurious warnings (Climate Control, PDC, a few others). Turned on and off a few times, some persisted, others cleared. Then I tried switching the ignition on and leaving the car for about 30 seconds. Seemed to go through all its checks. Then I started it. No more spurious warnings, for the three hour journey home.
Might be worth giving it a try and see what happens.
Hope this helps
Sent off a report to Ineos yesterday Gwynne but it’s bank holiday so don’t expect a reply till tomorrow.Hi there. I've signed a contract for a diesel grenadier with delivery due in July. I'm very concerned by the software and vibration issues reported here. If you've experienced these issues, and I'm really sorry if you have, can you confirm that you've reported them through your dealer and I'd be interested to know what Ineos are saying they will do to rectify it.
Where have you sent it exactly? Is there a nominated email address or person?Sent off a report to Ineos yesterday
Go to ”Settings”The one thing i can't find is how to turn off the see you home headlight settings??
Is there a setting for central locking where you can choose which doors unlock. I’d like the option to just unluck the front two with first press of the key fob.Go to ”Settings”
Then to “Vehicle Functions”
Then to “Central Locking”
There is an option here to allow you to change it
see page 159 in the manual
It’s in the same sub menu as above. I think you can separate the driver’s door to unlock on one press, and the rest on two presses. Not sure if you can select front two on one press and the rears on the second press. (I haven’t played with this at all)Is there a setting for central locking where you can choose which doors unlock. I’d like the option to just unluck the front two with first press of the key fob.![]()
Tom Johnson, head of VIP and Lynns hit man I think!Where have you sent it exactly? Is there a nominated email address or person?
Update
Truck has been standing for 16 hrs locked up.
Turned ignition on but did not start engine as suggested by Deepblue, all the faults have cleared apart from TPMS.
TPMS readings from front left clockwise: 42-41-43-44. Real tyre pressures: 37-36-37-38, I set them all at 37. So the TPMS system is over reading pressures by 5 psi at front and 6psi at back, this must be what was causing the warning of over pressure yesterday as the tyres heated up.
Software version is :- SW0000000353001939, I think this is the latest version, I put it in red as it needs improvement
Both Tom Johnson and Mark at JT Hughes have replied this morning by email (not bad on a bank holiday) and promising to fix it ASAP.
Plan. I have a circular rout from home that will at its furthest is only 10 mile from home. I recon if I drive round it for a couple of hours or until the problems start, it will give us more data to work from.
Maybe this is the man he'll call:Tom Johnson, head of VIP and Lynns hit man I think!
That promising.Update
From following JLR's recent history with software "updates", debugging seemed to mostly consist of switch off or removing checks that proved troublesome rather than fixing anything.Software version is :- SW0000000353001939, I think this is the latest version, I put it in red as it needs improvement![]()
Have you been given the breakdown assist number to call ~ do they have a mechanism to escalate direct to Ineos or their team of "flying spanners"?Plan. I have a circular rout from home that will at its furthest is only 10 mile from home. I recon if I drive round it for a couple of hours or until the problems start, it will give us more data to work from.
ThanksGo to ”Settings”
Interesting that the TPMS gives a excessive tyre pressure warning for 41-44 psi. I would have thought a lot of people would run the BFG’s at that sort of pressure regularly?? I know I generally run my AT’s at 40psi cold day to day on the black stuff. This normally equates to circa 44psi hot.TPMS readings from front left clockwise: 42-41-43-44. Real tyre pressures: 37-36-37-38, I set them all at 37. So the TPMS system is over reading pressures by 5 psi at front and 6psi at back, this must be what was causing the warning of over pressure yesterday as the tyres heated up.
I would have thought warnings would have more to do with rapid changes to pressures or one tyre being out of sync with the others?
So early 40’s not “excessive“ at all. (And I’ll still run 40 cold day to day). I wonder if the system can tell if you’re 3 up or 5 and a full boot?View attachment 7810891
From the draft manual.
