Won’t that cause your left foot to get extremely hot?There a really fat layer of insulation under and beside the footrest that I plan to remove and replace with carpet. Will free up 20-30mm.
How can the accelerator pedal be move back??... I am also going to move the accelerator pedal back 20mm so the foot rest, brake and pedal are nearly in line.
I remember saying that if there was a 'delete' kit at a couple of hundred pounds for the footrest I would likely buy it. That said, the current foot rest position gives me very little trouble. If there was good room to stretch my left leg occasionally I would not even think of changing the footrest.An owner being honest about the RHD footrest. Thank youo.
You like the vehicle and that is great news - I hope my wife likes it (had to convince for the cash a few years ago!).
The stretch is what I want more than moving the rest... but you can only go towards your body!I remember saying that if there was a 'delete' kit at a couple of hundred pounds for the footrest I would likely buy it. That said, the current foot rest position gives me very little trouble. If there was good room to stretch my left leg occasionally I would not even think of changing the footrest.
Pretty much exactly my experience (minus the error messages).Last Thursday was a beautiful sunny day and at 05:00 Hrs I set out with a full tank of fuel in my Diesel Powered, Grenadier Station Wagon optioned up with everything bar winches and roof rack. I wanted to give the Grenadier a good shake down having owned it for around six weeks.
My intention was a 700 mile round trip in the same day and I managed this with ease.
My journey took me from my home in Cheshire to Land End in Cornwall and back. The first 40 miles was along the A49 which is an A road full of mainly long, twisty sections. For most of this I was in CC at 55 mph. I am still trying to work out what is apparently so different about the steering. I approach a left hand bend, coax the wheel to the left and on completion of the manoeuvre, let the wheel slip through my hands as the steering straightens. The steering may be subtly slightly more vague than my wife's BMW X3 but not to an extent that I would notice. The car does not appear to role even when pressed which is different to my old Defender.
Once on the motorway I adjusted CC to 75 mph and continued the journey without stopping until joining the A38 duel carriageway some 170 miles later. The motorway journey was smooth and relatively quiet as in, the radio volume required no adjustment. I doubt it was a quiet as an SUV but definitely not an issue.
The journey continued without drama all the way down to Cornwall. At 4 hours behind the wheel I felt I needed to stop and have a stretch as I was beginning to move around a little in the seat. My stop was around 15 mins before completing my 7 hour journey to Lands End.
Following a couple of hours walk and relaxation once there, the journey home provided me with no dread. I decided to push the performance of the vehicle a little more and see how it affected the MPG which was just short of 28 MPG on the journey down. The journey home returned 25.5 MPG which on a vehicle of nearly 3 tonnes and only 1500 miles on the clock wasn't too bad.
The list of thoughts and observations which I noted on the journey were as follows and in no particular order:
Alarms:
Nearside Rear parking sensor anytime I put the car in reverse.
PDC warnings (centre screen only with no audible warning)
Continual 'Bong' on moving forward from stationary,
Power steering warnings, various other warnings that appeared randomly and without any change in performance, steering, feel, etc.
The drive itself:
A completely solid vehicle with no creaks, squeaks or rattles. Very confidence inspiring. Felt like I could take it anywhere and not break down. (completely subjective of course)
Door mirrors could provide a better field of view. (After market versions likely to arise)
Centre arm rest would benefit from being able to slide forward as in many other vehicles
Fuel gauge showed remaining range at 375 for over 100 miles before dropping off to a realistic level
MPG indicated proved accurate when tallied with litres of fuel used over mileage as recorded on gps
Lack of storage space in the cockpit. The only place for everything was drivers side pocket or the very small arm rest stowage. (Not sure how to address this via the aftermarket but happy to live with it)
USB outlets definitely not in the best place. (This can easily be fixed by adding in more suitable locations)
The stowage tray area in front of gear levers is virtually useless. None stick surface doesn't help.
The stowage tray area in front of steering wheel is of no use without modification by way of none slip matt
Car Play and user friendliness of screen is questionable but likely to improve over time and with subsequent software updates
Foot rest was not an issue unless I thought about it. It is difficult to stretch the left leg without passing your foot over the foot break. This is possible but not ideal. Following 700 miles in one day, my left leg, knee, ankle had not suffered. Unfortunately I am afflicted with Osteoarthritis in my lower limbs so was happy to report great comfort levels all round.
Spotted the slight vibration through the drive train that appears at around 1800 rpm. I also felt that a software update on the transmission might improve the responsiveness when pulling away at lights or from a junction. Currently feels like the engine has to rev in order to get motion from standstill.
Aircon worked really well despite the hot day (fan noise can be intrusive as with many vehicles)
Seat comfort perfect for 4 hours without a break
Enjoyed the interior aesthetics. Very pleasing to the eye as is the saddle leather wheel, etc which I was glad I optioned. (another last minute decision)
Cabin noise was not an issue although not as quiet as my wife's BMW X3
Really like the safari windows which for me were a last minute option. Provide a lot of light. Might not be so good in the southern hemisphere but brilliant in the UK
Steering was great over all driving conditions. I really enjoy driving the Grenadier.
Lights at night were superb and as good as anything I have driven.
Lots of compliments anytime I stopped
Whilst navigating the smaller streets of Falmouth and one or two tiny villages I concluded that living with this car in the city may come with a few challenges. Doing a 180 on a mini round a bout is not an option. Three point turns become four / five turns. Parking in small car parks needs some thought.
Overall I am over the moon with the Grenadier. It is a blank canvas on which we can all adjust and modify to suit our various requirements. For me, Ineos have produced a winner at the first attempt. A true successor to the old Defender. Let's hope for a rapid improvement in their customer relations and support services both of which are not yet where they should be.
@Cheshire cat Thank you for the detailed report. I will follow part of the route soon.Last Thursday was a beautiful sunny day and at 05:00 Hrs I set out with a full tank of fuel in my Diesel Powered, Grenadier Station Wagon optioned up with everything bar winches and roof rack. I wanted to give the Grenadier a good shake down having owned it for around six weeks.
Alarms:
The drive itself:
Just edited my incorrect post. It seems only my cigarette lighter is powered via roof switch. I have a USB converter plugged into that fitting.Pretty much exactly my experience (minus the error messages).
- cabin noise - yes a bit intrusive and I did get bored with this after 3 hours but then you are moving a huge wall through air. Feel like I'm creating a vacuum behind me that might suck in small children.
- no compliments or waves. a few startled looks and people mouthing "WTF is that?" to themselves (though mainly when I went past them at 80) but that's about it.
- reversing camera - never had one before so loving this!
- USB yes a pain. The interior power-on when ignition off button only seems to power the rear passenger USBs and not the stowage box ones.
- Need more interior storage - yes. Kept losing my Twirl chocolate as it flew around the cabin while cornering (all long journeys need a few Twirls)
- Never losing it in a car park - I lost my grey VW Touran in a large Tesco car park for 20 min once.
I don't need it.Do you have the wife's permission to say that?
Actually we don't have my money and her moneyTo be honest, she really shouldn't have any say in what you do with her money either.![]()
Large Stilsens and a hammerHow can the accelerator pedal be move back??
Will be very interested to hear how you get on with this modification. Please keep us all posted.There a really fat layer of insulation under and beside the footrest that I plan to remove and replace with carpet. Will free up 20-30mm. I am also going to move the accelerator pedal back 20mm so the foot rest, brake and pedal are nearly in line. Will then put the seat further back and have the steering wheel all the way back. I have already tried it and makes a massive difference. Works for me as I’m only 5’8. Might not work for someone taller
Retired and spends her time reading this forumActually we don't have my money and her money
Never have
Particularly now that I am still working and she has retired.
Nice overview on the car....cheers! It is incredible that a car as big as the Grenadier has such limited storage space in the cabin. I think this is the only thing that really disappoints....it's a bit of a miss fo ra car with it's intended purpose.Last Thursday was a beautiful sunny day and at 05:00 Hrs I set out with a full tank of fuel in my Diesel Powered, Grenadier Station Wagon optioned up with everything bar winches and roof rack. I wanted to give the Grenadier a good shake down having owned it for around six weeks.
Alarms:
The drive itself:
5 week old Fieldmaster. 1250 miles now. Overall impression is that it is very solid and heavily built. (I'm a former Landrover Dealer Principal - owned many 110s) Feels substantial - more like a G-Wagon than a landy. We also have a new Defender 110. Defender probably more of a 'lifestyle' driver's car, but lighter built and less room inside. I find it easy to rest my left foot out of the way as I do with all the autos I drive. I don't ever notive the bulge in the floor. Currently 27MPG - improving a little as it loosens up. It's a long way down from this high vehicle so I'm concerened about wearing the side bolster on the seat as I slide out. Getting in using the side step is easier. Some annoying resonance from the metal heat shields, particularly under the rear. This will be sorted on my dealer visit to get a rear door table fitted. Towing 3500KG it is superb and totally competent. Much more rigid than a pickup truck. Quite a good sound system. Still getting used to the functions on the central display. I need to read the manual! Feels like it has been built to last. Very pleased so far. Day 1 video:All these Grenadiers that are now on the road and hardly a few words put together describing first impressions. Photographs are all very well but we want to hear how it makes one feel. What is ones impressions compared to recent journalistic reviews. We are hanging on every word but unfortunately, no words are coming through.
Hi Stuart just an observation - if you were born in 1927 you've done well to get in a Grenadier!!!Nice overview on the car....cheers! It is incredible that a car as big as the Grenadier has such limited storage space in the cabin. I think this is the only thing that really disappoints....it's a bit of a miss fo ra car with it's intended purpose.
You have your own thread...5 week old Fieldmaster. 1250 miles now. Overall impression is that it is very solid and heavily built. (I'm a former Landrover Dealer Principal - owned many 110s) Feels substantial - more like a G-Wagon than a landy. We also have a new Defender 110. Defender probably more of a 'lifestyle' driver's car, but lighter built and less room inside. I find it easy to rest my left foot out of the way as I do with all the autos I drive. I don't ever notive the bulge in the floor. Currently 27MPG - improving a little as it loosens up. It's a long way down from this high vehicle so I'm concerened about wearing the side bolster on the seat as I slide out. Getting in using the side step is easier. Some annoying resonance from the metal heat shields, particularly under the rear. This will be sorted on my dealer visit to get a rear door table fitted. Towing 3500KG it is superb and totally competent. Much more rigid than a pickup truck. Quite a good sound system. Still getting used to the functions on the central display. I need to read the manual! Feels like it has been built to last. Very pleased so far. Day 1 video:View: https://www.youtube.com/watch?v=oB_DEa5mIos
Splendid long view. I havent even done 700 miles in the 6 weeks of ownership, but have very similar views of performance , fit and finish. Storage for bits and bobs is my number one feedback to IA plus the inadequate USB location. Capability is without a doubt its best feature, and the interest it attracts is quite staggering.Last Thursday was a beautiful sunny day and at 05:00 Hrs I set out with a full tank of fuel in my Diesel Powered, Grenadier Station Wagon optioned up with everything bar winches and roof rack. I wanted to give the Grenadier a good shake down having owned it for around six weeks.
Alarms:
The drive itself:
