Show us your crack (windshields)
If your windshield cracked (please answer honestly)
  • Diesel : NO evidence of stone chip or damage prior to crack appearing
    Votes: 16 7.9%
  • Diesel : evidence of stone chip or damage prior to crack appearing
    Votes: 26 12.9%
  • Petrol/Gas: NO evidence of stone chip or damage prior to crack appearing
    Votes: 35 17.3%
  • Petrol/Gas : evidence of stone chip or damage prior to crack appearing
    Votes: 50 24.8%
  • No crack
    Votes: 75 37.1%
  • Total voters
    202
So you have exercised your windshield in various scenarios of temperature extremes and no cracking huh?
The trimming I was thinking of is illustrated below.. blue is the rubber trim and black is windshield. Trim via the dashed line, to fit the curve of the windshield. This won’t work you say?
That looks like a good way to do it. I keep my defroster in the blue. 70 degrees. No problems yet.
I wonder if a piece of gravel or some other stone could get wedged between the bottom of the windshield and the body.
Then, as heat is applied and the glass expands, the crack starts where the stone is pinched.
How long from your seeking repair from RDS to installation?
I already had an appointment set up for me 12mo service set for February. They are scheduling glass replacement when I go in for that. Until then I am watching my crack slowly work its way across the screen. Since the crack it's only spread about an inch farther, it has gone from vertical to walking more horizontally now.
Thanks. I was trying to figure out whether to install a film over the windshield. They have drawbacks but would make sense if you had to wait for months to replace the windshield.
Sigh!! I have this exact thing. There doesn’t seem to be any impact. Irritating. Insurance sill
Cover it, but I have pretty high deductible. My whole life this is the first cracked windshield. I was driving 30-40 mph and there was nobody in front of me. I heard a crack. My son heard it too. I didn’t immediately see the crack, but sure enough if h a minute or two later there it was. Grrrrrr!
That is what mine is doing.
The dealer in Maryland is trying out different films. They haven’t found a good one yet.
I liked the look and thickness of the Racing Optics windshield defense. It installed easy. I did run clear tape along the top edge, the film ended 3/8" or so below the top edge, car wash jets kept blasting about 1/4' of film up off the window. Added the tape and it held just fine. I'll add Windshield Defense again with the new window. I'm adamant it was not a rock strike, I fully believe it's the defrost heat. Even when I'm not on defrost it still blows lightly, when the crack showed up it was very cold and my defrost was set on high while the car idled for about 4 hours. I have since held my hand on the defrost when set full speed full heat and it is VERY hot. I've stopped using the defrost unless I actually need to warm the windshield. I'm also 3d printing a deflector to keep defrost from hitting the first few inches on the bottom of the windshield.
Second crack in the windshield. It looks like a minor nick in the lower black seal area centered above the idiot lights of the dash. I mean, pinhead sized pit. tiny.
These windshields are recall level garbage.
Yea, I know its flat, but I have 350k on a 96 G, 2 fj 40's, multiple 60's farm pickups, 2 fj60's, an fj55, and isuzu troopers. I have been driving insane amounts of miles in my life in bricks, and some of it at retardo speeds in third world countries, and outside of an f350 that fell victim to a hate crime in '17, I have never replaced a windshield. The G looks like I drive thru sandstorms in the late winter evenings. In 3k miles, two cracks with a Gren. As one person, it's anecdotal... with 7 figure miles under my belt, I'm a breathing test case. These windshields are low bid garbage bull SHIT.
I do have glass protection.
Back to your evening programming.
I tried to make it go around the corner on the right without cuts and kinda made a dog's breakfast of it. Put relief cuts in the left corner and it might be a little better. Been on there a year now and I don't notice at all.
Other than the corners, it looks great.
Terminated at the top corners.
View attachment 7884900View attachment 7884901View attachment 7884902View attachment 7884903
I did a similar thing using a Z shaped trim from Amazon, I cut off the bottom edge of the Z to make it more of an L which made it easier to go around the corners. Its not a super hard rubber so will probably have to be redone in a year or two, but cheap and easy to do.
Do you have a link for the Z trim. I see varying sizes and yours looks great so I'd like to order the same. New windshield goes on next week so with this trim, defrost deflector, Racing Optics I am hoping the $300 in preventative will work to make the windshield as protected as possible.
Not an invitation for our antipodean friends to photograph their arses but rather our windscreens.
I saw a thread on one of the Facebook groups where it seems a common occurrence for a mystery crack to appear in the middle of the bottom edge of the screen. 5 or 6 people reported the exact same thing.
I wasn’t aware of a stone chip but I jumped in one day and saw immediately a 3-4” curving crack that actually follows the shape of the wiper pattern. It’s grown and grown but screen is being replaced tomorrow.
Anyone on here had this?
I have started to save pics of cracked windscreens. Out of the 27 I have collected, more than 50% look similar to yours. This simply can not be coincidence. Not sure how to proceed, if at all. My first broken screen looks identical. very frustrating!
The other factor is the defrost vent is in the middle. So perhaps the effects from the windshield impact is made worse by more extreme temp delta? In that lower center portion?
Mine cracked when the heating was on pretty high and it was -6c outside. It started from the vent area. However, there was ricochet damage on the outer rim of the glass.
This is what I used, as mentioned you need to cut off the lower edge to make it an L shape (not too hard to do just using scissors).
https://amzn.asia/d/8RtyZi1
Hmm how did that rubber turn around the corner without bunching up? Did you do relive cuts?
It’s a soft rubber (or is it a rubberized foam?) so if you are careful you can massage the strip on the corners to remove bunching and ripples. The outer section on the edge of the screen bows out slightly on the corners which helps keep the curve on the windscreen face smooth.
Sigh... 1,960 miles (2 months) into my Grenadier and I had to change my vote here.
Thanks to the wonderful Bay Area roads I have now joined the club.
I'm hopeful if I take it to a shop they might be able to do some epoxy fill. Thankfully its on the passenger side. But still very noticeable!
