Show us your crack (windshields)
If your windshield cracked (please answer honestly)
  • Diesel : NO evidence of stone chip or damage prior to crack appearing
    Votes: 15 8.5%
  • Diesel : evidence of stone chip or damage prior to crack appearing
    Votes: 24 13.6%
  • Petrol/Gas: NO evidence of stone chip or damage prior to crack appearing
    Votes: 29 16.5%
  • Petrol/Gas : evidence of stone chip or damage prior to crack appearing
    Votes: 40 22.7%
  • No crack
    Votes: 68 38.6%
  • Total voters
    176
I have started to save pics of cracked windscreens. Out of the 27 I have collected, more than 50% look similar to yours. This simply can not be coincidence. Not sure how to proceed, if at all. My first broken screen looks identical. very frustrating!
The other factor is the defrost vent is in the middle. So perhaps the effects from the windshield impact is made worse by more extreme temp delta? In that lower center portion?
Mine cracked when the heating was on pretty high and it was -6c outside. It started from the vent area. However, there was ricochet damage on the outer rim of the glass.
Do you have a link for the Z trim. I see varying sizes and yours looks great so I'd like to order the same. New windshield goes on next week so with this trim, defrost deflector, Racing Optics I am hoping the $300 in preventative will work to make the windshield as protected as possible.
This is what I used, as mentioned you need to cut off the lower edge to make it an L shape (not too hard to do just using scissors).
https://amzn.asia/d/8RtyZi1
Hmm how did that rubber turn around the corner without bunching up? Did you do relive cuts?
It’s a soft rubber (or is it a rubberized foam?) so if you are careful you can massage the strip on the corners to remove bunching and ripples. The outer section on the edge of the screen bows out slightly on the corners which helps keep the curve on the windscreen face smooth.
